High Current Class A Amplifier Supply
I'm building a Nelson Pass Aleph 4 Class A Amplifer.
It uses a 40-0-40 VDC + 6A Power Supply per channel.
Using 500VA transformers and 50A Bridges, I have the components for two completely separate power supplies.
I have:
12 x 33000uF Computer Grade Caps.
4 x 22mH 15A Air Cored Inductors
4 x 0R47 25W Resistors.
It is intended to uses 3 x 33000uF capacitors per supply:
LEFT +ve
LEFT -ve
RIGHT +ve
RIGHT -ve
Question is, What is the best combination of C, R and L for this supply.
Previously the same capacitors worked beautifully as CCC (no R or L)
I'm guessing at CRCLC but I need someone with some SPICE experience to comment on how best to use the components avaialble.
