I have been dreaming of getting a particular 600W class D amplifier module that can operate off of up to 84V rails. I realized that 84VDC can be obtained from rectified 60VAC. I know that there are many super cheap step-up/step-down transformers that just have a 2:1 turns ratio and I could connect that to my USA power grid @120VAC to get out 60VAC, which I would rectify to get my rails. Then it also dawned on me that these might be cheap because they are actually autoformers, which don't provide any isolation. This means shock danger if there is a fault.
So, can I use a cheap step up/down transformer or should I avoid because they are autoformers? Should I just avoid step-up/down transformer (not necessarily autoformers) in general because of other reasons???
-Charlie
-Charlie
Well I found a web page that confirms my fears...
Never Use a Surge Protector with a Step-Down Transformer
I will definitely avoid getting a power supply transformer on the cheap by using a $19.99 step up/down transformer from Ebay!
-Charlie
-Charlie
From another angle, you could look for vintage or newer high powered receivers not working from thrifts or yard sales.
I've salvaged many large high quality transformers from the like.
Not always easy to find but they are out there.
Saves bucks as we know the transformers are usually the most expensive part of DIY.
- Power Supplies
- cheap transformer or cheap death?
