Need Negative High Voltage Regulator Circuit
Old 14th September 2018, 12:12 PM   #21
obiwankenobi is offline obiwankenobi  Argentina
obiwankenobi's Avatar
You get a rejection of 50dB instead of 70dB because you didn't use the normalized unity stimulus for the Bode plot: you used 12, which represents a penalty of more than 20dB.
Thank you Elvee. Copied your interesting suggestions and I'll be back for small details if you don't mind. I will redraw a proposed circuit for my particular needs and try to find suitable transistors and MOSFET.
I am really a newbie to LTspice and so, could you please tell me how to instruct LTspice to plot correctly the -70dB as your plot ? I couldn't find such a setting for
normalized unity stimulus for the Bode plot...
Is this an LTspice setting or is it that my input generator signal needs to be changed, when yo say "you used 12"
Kay Pirinha,
Otherwise I'd recommend a Maida style regulator
what is a Maida style regulator ? Could you please be so kind to post a sample or link to it ?
Old 14th September 2018, 12:59 PM   #22
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
National Semiconductors LB 47
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 14th September 2018, 08:15 PM   #23
Elvee is offline Elvee  Belgium
Elvee's Avatar
You need to enter "1" in the amplitude box, unless you know exactly why you need to enter a different value, see below
Kay Pirinha,
A Maida is definitely better than a straight monolithic regulator used outside its comfort zone, but the main pass element remains the VR, even inside the cocooning and protection of discretes, and as such is much more vulnerable to abuse than a fully discrete voltage regulator designed for the target voltage/current combination.
In addition, the Maida is not exactly a LDO, quite the opposite in fact.
The simple 2 transistor example of this thread doesn't reach the performance level of a Maida, but there are alternatives: I have also described other series regulators that are a bit more complex, but have performance on a par with Maida's.
If really top performance is required, the best option is a discrete pass element combined with an opamp and a good reference.
It sounds complicated but it needs not be, and it offers better performance than a Maida, combined with the robustness of discretes
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Need Negative High Voltage Regulator CircuitHide this!Advertise here!
HELP!!! J110 negative voltage regulator texaslonghorn Parts 0 8th April 2010 04:27 AM
High Voltage negative regulators Tweeker Tubes / Valves 3 27th February 2009 12:14 AM
Positive regulator to produce negative voltage? stef1777 Parts 45 8th February 2008 07:46 AM
why do we need negative voltage regulator ICs? EJ Solid State 19 22nd August 2003 12:38 PM
high voltage (>>37 V) negative regulator? capslock Solid State 14 7th September 2002 11:41 PM
