Keantoken's CFP cap multiplier
Keantoken's CFP cap multiplier Please consider donating to help us continue to serve you.
Old 11th March 2016, 08:41 AM   #911
Krissz80 is offline Krissz80  Hungary
Originally Posted by keantoken View Post
Remove the 10nF caps, in some circuits they are a last resort but are rarely optimal for a fast or low noise circuit. The BC337 should not age, if so then they have been abused.
The 100nF can actually cause oscillating by making a peak in the source impedance. I suggest instead you use Wima 10uF or Vishay MKP416 1uF. This will go much farther towards the goal of low ESR film bypass.
wima 10uf WIMA 10 uF 5 mm Film Capacitors | Mouser
10uF Wima parallel to each elko (100uF & 820uF)?
Old 11th March 2016, 09:13 AM   #912
keantoken is offline keantoken  United States
keantoken's Avatar
Yes.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 11th March 2016, 09:46 AM   #913
OK.
And what could cause that the drop of the K-multi increased.
With 14,2V with BD140 the output was 6,5V.
I've changed the BD to TIP42C, and the drop decreased, the output goes up to 10,7 V.
I've measured the BD140 after solder out, and it was good.
Now I've increased the input voltage, but don't knwo if it cause any problem.
Old 14th March 2016, 03:38 AM   #914
alexkosha is offline alexkosha  United States
alexkosha's Avatar
Originally Posted by TNT View Post
Good on ya'!!
I'd be interested.
I would be interested on several boards too, for 45V and 100V versions.
Any ETA on these?
Old 14th March 2016, 05:34 AM   #915
keantoken's Avatar
Originally Posted by Krissz80 View Post
OK.
Sounds like your circuit is overloaded, or maybe Q1 has C and E swapped. Also check the 47R resistor with a DMM to make sure it's the right value.
Old 14th March 2016, 05:40 AM   #916
keantoken's Avatar
Any ETA on these?
I sent some of the 50V PCBs to print and they are at the fab right now. If they turn out well and test fine I can sell some as soon as I get them (could be 2 week or longer).
I will have to make a different PCB for the 100V version, but you could make one by soldering on a bunch of diodes on to the 50V PCB. How much input ripple would you expect?
Old 14th March 2016, 05:45 AM   #917
alexkosha's Avatar
About 300-500mV on input, the max. Need 1-10mV output from KM.
Sent from my iPhone using Tapatalk
Old 14th March 2016, 11:13 PM   #918
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Interested in 4 boards
RC
Old 14th March 2016, 11:34 PM   #919
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Interested in some boards,whats the price?
Regards Åke
Old 15th March 2016, 10:01 PM   #920
keantoken's Avatar
For now I'll say $4 per board plus shipping.
Keantoken's CFP cap multiplierHide this!Advertise here!
Vbe multiplier - bypass cap Donk Solid State 7 22nd January 2008 02:55 AM
Question(s) about CFP. Justcallmedad Solid State 94 20th September 2005 11:08 AM
cap multiplier or not? PederBass Solid State 13 23rd March 2004 07:26 PM
Cap. multiplier or regulated supply ? Buhl Pass Labs 1 8th October 2003 11:51 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
