Keantoken's CFP cap multiplier
Old 22nd November 2015, 01:57 PM   #891
rensli is offline rensli  Estonia
rensli's Avatar
Some fotos:
Filter capacitors are all the same brands in LM and k-mult filter-bank.
All samwha-s, dirty cheap. Capacitance amount is also the same 2200uf + 2x 470uF.
Sound still so different
Old 22nd December 2015, 03:20 PM   #892
Krissz80 is offline Krissz80  Hungary
Hi all!
I'm new here, and I have a problem with K-multi (positive version).
I've built the K-multi width BD140-16 and 1 piece of 1N4148 diode.
And I've put in the LED in opposite direction (but theoretically it should not make any difference).
In addition I use a 10nF X7R between the B-E leg of the BC337, and I use one 100nF X7R parallel to each elektrolite capacitor.
The input is voltage came from a stabilizator circuit width LM1084.
This is it's output characteristic measured by Scope.
The output is 12v 1,2A (load resistance was 10 ohm 20W).
After I connected the K-multi to the stabilizator circuit I got the following result measured by Scope.
Can anybody tell me why is it have 25MHz sinus noise on it.
Old 19th February 2016, 11:09 AM   #893
av-trouvaille is offline av-trouvaille  Netherlands
It seems up to now, the K-multiplier presupposes a power supply with C-filter to smooth the DC input voltage (so an elco of significant capacitance after the bridge rectifier). In terms of function a K-multiplier might be seen as a substitute for a choke. So, the K-multiplier as an electronic choke. Would it be allowed to use a K-multiplier as a choke-input filter? That is, a K-multiplier right after the diode bridge, and the smoothing C after the K-multiplier?
I only ask whether it is technically allowed, not if it would be the optimal place.
Old 19th February 2016, 06:33 PM   #894
keantoken is offline keantoken  United States
keantoken's Avatar
A large inductor right after the rectifiers can see extreme ripple and negative voltage at the input. This is far beyond the scope of the KM. There must be at least enough capacitance at the input to bring ripple down to it's working range.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 19th February 2016, 07:19 PM   #895
Yes, I am aware that a large inductor right after the rectifiers can see extreme ripple and negative voltage at the input. I notice that in the choke input filters for my tube amps. But its peak would diminish fast as soon as current is drawn. Is it an option to simply add a zener of appropriate voltage between the rectifier and the K-multiplier to tame the peak?
Old 19th February 2016, 07:26 PM   #896
keantoken's Avatar
Originally Posted by Krissz80 View Post
Hi all!
Sorry I missed this. Can you tell me why you made those changes? If anything the 10nF cap should go on the B-E of the BD140. And I think I have seen more than one KM using the BD140 that oscillated.
The KM should have capacitors close to both the input and output, but 100nF film caps are unnecessary and sometimes will even cause oscillation.
Old 19th February 2016, 07:32 PM   #897
keantoken's Avatar
The KM would have to turn on and off to charge the reservoirs, and a zener does not store power and so cannot support the input voltage of the KM when input is low. A zener to reduce the positive peaks would either short the rectifier or it would go across the KM, effectively bypassing it and ruining the goal of filtering.
Old 19th February 2016, 08:56 PM   #898
Thanks for clarifing. No choke input with the K-multiplier for me, then.
Old 21st February 2016, 01:44 PM   #899
Another question to explore the versatility of the K-multiplier, when allowed.
The current capability of the K-multiplier is limited to about 1A. Earlier you mentioned it is hard to design for more current.
Would it be feasable to increase the current capability by putting two K-multipliers in parallel?
Old 21st February 2016, 02:13 PM   #900
keantoken's Avatar
The power can be increased by using parallel degenerated transistors. However you can overload the driver.
Keantoken's CFP cap multiplierHide this!Advertise here!
Vbe multiplier - bypass cap Donk Solid State 7 22nd January 2008 02:55 AM
Question(s) about CFP. Justcallmedad Solid State 94 20th September 2005 11:08 AM
cap multiplier or not? PederBass Solid State 13 23rd March 2004 07:26 PM
Cap. multiplier or regulated supply ? Buhl Pass Labs 1 8th October 2003 11:51 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
