Keantoken's CFP cap multiplier
Old 26th October 2015, 06:36 AM   #881
keantoken is offline keantoken  United States
keantoken's Avatar
2SC4793/A1830 work if you don't need the last few hundred mA provided by the original transistors.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 26th October 2015, 12:02 PM   #882
marsupialx is offline marsupialx  United States
marsupialx's Avatar
Did you mean 2sc4793 / 2SA1837? That I can find. Thanks!!!
Old 5th November 2015, 04:43 PM   #883
marsupialx's Avatar
Found 1930e / 5171e Fairchild transistors. Building soon!!!
Old 5th November 2015, 05:45 PM   #884
keantoken's Avatar
Fairchild doesn't make those AFAIK.
Old 5th November 2015, 05:50 PM   #885
R.I.P.
I have the 2sa1930 datasheet and it is Toshiba. That doesn't exclude Fairchild.
The case style is SC-67/2-10R1Aand looks like a fully enclosed type with insulated backplate.
regards Andrew T.
Old 5th November 2015, 10:00 PM   #886
marsupialx's Avatar
I was confused. These are the exact parts. It was the other transistors that I got from the same person that were Fairchild. I knew I'd confused y'all, but I didn't have an opportunity to correct my post. Sorry!!!
Old 6th November 2015, 04:33 PM   #887
alexkosha is offline alexkosha  United States
alexkosha's Avatar
If I may... There are plenty of 2SA1930 in Mouser or DigiKey. And 2SA5171 I acquired from eBay guy. Please see attached picture.Click the image to open in full size.Click the image to open in full size.
I used already 3 of them and seems they are original Toshiba made transistors. No issues what so ever...
I'll send you guys a link to that eBay source.
Sent from my iPhone using Tapatalk
Old 6th November 2015, 04:38 PM   #888
alexkosha's Avatar
Here it is and relatively cheap:
http://www.ebay.com/ulk/itm/181363181214
Old 6th November 2015, 08:01 PM   #889
marsupialx's Avatar
Thank you very much!!! It's so hard to tell if Ebay parts are going to be genuine. It's good to know that those are! Thanks again.
Old 22nd November 2015, 12:55 PM   #890
rensli is offline rensli  Estonia
rensli's Avatar
keantoken, i finally had time to test your circuit in real action.
Yesterday, i was modifying the Texas tidu34 volume control. Got it sounding just right with LM317AT+LM337AT. Using Thailand NE5532 and OPA2134 from texas.
Tidu34 controls the volume for naim NAP140 clone amplifier.
The i had an idea to try you K-multiplier:
1. Took a transformer 14VA
2. Built PSU filter with LOW ESR 470uF electrolytes.(CRCRC, R= 330mR)
3. At the last electrolyte from Filter-Bank, installed there k-multiplier.
Output before k-mult = 16V +/- VDC
Output from k.mult = 14V +-/ VDC
While soldering stuff together i was listening to LM regulator PSU.
Cut the power off Tidu34, replaced LM regulator psu with filterbank + k-mult.
Turn on and WoW, everything is sooo different... soundstage/dynamics/acoustic are completely new story lol.... how is it possible
First i tought, its the filter in AC 230V line, today i removed the AC filter, sound is still same
I miss that relay switch to compare between different amps and speakers(and also switch between PSus)... i will get on it and then will tell the difference lol
Keantoken's CFP cap multiplierHide this!Advertise here!
Vbe multiplier - bypass cap Donk Solid State 7 22nd January 2008 02:55 AM
Question(s) about CFP. Justcallmedad Solid State 94 20th September 2005 11:08 AM
cap multiplier or not? PederBass Solid State 13 23rd March 2004 07:26 PM
Cap. multiplier or regulated supply ? Buhl Pass Labs 1 8th October 2003 11:51 PM
Copyright ©1999-2019 diyAudio
