Keantoken's CFP cap multiplier
Thread Tools
Old 11th April 2015, 01:13 PM   #821
sikahr is offline sikahr  Croatia
sikahr's Avatar
Like this?
Old 11th April 2015, 01:28 PM   #822
jameshillj is offline jameshillj  Australia
4 diodes, not a GB bridge (soft recovery, schottky, smd, etc) - shorten tracks by Input one end of pcb & o/p the other end - snubber is applied directly across sec winding = 0.01uF in // to a 0.15uF + 1/2 watt resistor to suit (Haggerman type) - add option to use 2 resistors in '+ rail' and 2 resistors in '- rail' for the C-R-C filter - add option for extra resistors for R-C-R-C filters - Single layer, NO ground plane - maybe R + led indicator - optional power load resistor on o/p - etc
Old 11th April 2015, 03:03 PM   #823
sikahr's Avatar
Originally Posted by jameshillj View Post
1.
2.
3.
4. add option to use 2 resistors in '+ rail' and 2 resistors in '- rail' for the C-R-C filter
5.
6.
7.
8.
optional power load resistor on o/p -c
1. board is so small, 5x5 cm, no room for disrete diodes, complicates layout, but OK maybe
2. no room for conectors on sides
3. OK
4. dont understand, this board is for one rail not for both (you need two), it has CRC (pi) filter
5. maybe
6. no ground plane OK, but needs 2 layer
7. I'll try to find room
8. bleeder, OK
Old 11th April 2015, 03:24 PM   #824
TNT is offline TNT  Sweden
So same traces on both sides? For less resistance? This makes it very hard to de-solder and remove components without braking one side traces?
Old 11th April 2015, 03:31 PM   #825
sikahr's Avatar
No, last version is without that.
Old 11th April 2015, 03:38 PM   #826
OK! Well, I'm devoted to SMPS (+ C mult) so I will pass this one. Still, a welcome contribution I'm sure.
Old 11th April 2015, 03:39 PM   #827
Best to keep line carried noise, charging current pulses, etc concentrated in area of raw supply and as the cct on post #790 requires +/- rail volts with the single 0 volt connection, use single pcb for both rails, despite the larger size and feed maybe 2 CMx (for 2 channel signals) - look outside the square a bit
Single layer only maybe - simplify tracking and avoid capacitor 2 layer thru hole soldering - maybe larger smd power resistors underneath - is central 0 volt point connection at input, output of CMx board(s) or another point in the circuit (following regulator, active circuit, etc)?
Some suggestions only ...
Old 11th April 2015, 03:47 PM   #828
sikahr's Avatar
* added faston terminals
* added input snubber, cap two footprint, 1206 smd + 0.2" through hole
* added output resistor (bleeder)
Old 11th April 2015, 07:27 PM   #829
sikahr's Avatar
Old 11th April 2015, 07:30 PM   #830
sikahr's Avatar
One more
Keantoken's CFP cap multiplierHide this!Advertise here!
Thread Tools
Vbe multiplier - bypass cap Donk Solid State 7 22nd January 2008 02:55 AM
Question(s) about CFP. Justcallmedad Solid State 94 20th September 2005 11:08 AM
cap multiplier or not? PederBass Solid State 13 23rd March 2004 07:26 PM
Cap. multiplier or regulated supply ? Buhl Pass Labs 1 8th October 2003 11:51 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
