Keantoken's CFP cap multiplier
Old 3rd April 2015, 06:46 AM   #811
TNT is offline TNT  Sweden
DirtyPCBs.com order #200xxxx status: Shipped
Cant take 8 weeks can it?
Old 3rd April 2015, 08:07 AM   #812
sikahr is offline sikahr  Croatia
sikahr's Avatar
Earlier PCBs from Dirty, 3-4 weeks
Old 4th April 2015, 05:46 PM   #813
Santa Claws is offline Santa Claws  United Kingdom
Default Kuartlotron on 5x5?
Kuartlotron on 5x5?
Oh Yes that would be soooooo good! I'll take 20 or so.
Old 4th April 2015, 06:17 PM   #814
sikahr's Avatar
Originally Posted by Santa Claws View Post
Kuartlotron on 5x5?
The Kuartlotron - keantoken's simple error-correction superbuffer
Old 11th April 2015, 09:49 AM   #815
sikahr's Avatar
unregulated supply PCB, pi filter, needed before K mulitplier or superregulator, what do you think about layout (some parts are missing, snubers, bleeders ...)?
I tried to keep loops small.
Board is universal one positive or negative rail. Caps are 16mm diameter.
Old 11th April 2015, 10:49 AM   #816
R.I.P.
Your layout is not good.
The input to the first smoothing cap shares a link with the output from that first smoothing cap.
The OUTPUT must be on a separate trace from the INPUT to every pin on EVERY capacitor.
Follow the -ve trace, here you have separated the Input from the Output for every -ve pin.
regards Andrew T.
Old 11th April 2015, 11:24 AM   #817
sikahr's Avatar
Like this? Top&bottom layers are the same.
Do you have suggestions for some additional components?
Old 11th April 2015, 11:41 AM   #818
R.I.P.
YES !!!!
now close up the loop areas.
Or use the two layer board to place one trace above/below the complementary trace.
Make the In/Out pads big enough to suit using " spades that are soldered strongly on both sides of the PCB. Needs 4 extra holes compared to the terminals but preserve the pin pitch so that either spades, or terminals, can be used.
Is there room to add a snubber to the Input?
regards Andrew T.
Old 11th April 2015, 11:52 AM   #819
sikahr's Avatar
YES !!!!
1.
2.
3.
1. Can you please better explain
2. " spades, have some pictures?
3. I.ll try to find place, resistor and cap serial at AC? how large footprint for cap?
Old 11th April 2015, 12:03 PM   #820
R.I.P.
push the +ve trace close to the -ve trace so that the gap between the two is very small = low loop area.
"faston" are another name for spade (male) and push-on terminal (female)
quite small, try 0.1" and 0.2" pin pitch and make the 0.1" just close enough to allow a 1206 smd cap to be used between the pads.
Due to the capacitor blocking the DC and most of the 50/60Hz, the power dissipation in the resistor is very small. A standard W would do. The European 600mW are about the same size as W and fit a 0.4" pin pitch. 0.45" is a nicer fit and saves bending the leads as close to the resistor body. Alternatively the resistor could be stood on end with a 0.1" pin pitch, but many Builders do not like this.
regards Andrew T.
Keantoken's CFP cap multiplierHide this!Advertise here!
Vbe multiplier - bypass cap Donk Solid State 7 22nd January 2008 01:55 AM
Question(s) about CFP. Justcallmedad Solid State 94 20th September 2005 10:08 AM
cap multiplier or not? PederBass Solid State 13 23rd March 2004 06:26 PM
Cap. multiplier or regulated supply ? Buhl Pass Labs 1 8th October 2003 10:51 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
