Keantoken's CFP cap multiplier
Old 7th May 2014, 02:20 PM   #701
buzzforb is offline buzzforb  United States
buzzforb's Avatar
As i stated earlier, i replaced the BC337 this morning. Now both channels measure the same with the exception of the imbalance on one channel. It is small enought that I am proceeding. There is less than 1mV of ripple, so I am assuming all is well in the land of Oz.
...Shape the sound , Man!
Old 7th May 2014, 04:10 PM   #702
alexkosha is offline alexkosha  United States
alexkosha's Avatar
I use another KM board for my J-Mo Mk II headphone amplifier.
Excellent results!
About 2V drop and it is feeding Salas BIB. Very clean power!
Old 8th May 2014, 04:57 AM   #703
keantoken is offline keantoken  United States
keantoken's Avatar
Sounds good then Buzz, it looks like you are getting the benefits of the Kmultiplier even with the strange result. I would measure ripple again while under load to check if output impedance is okay.
Looks good Alex, I'm glad you like the result.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 10th May 2014, 04:18 PM   #704
tarcuper is offline tarcuper  Hungary
tarcuper's Avatar
Dear keantoken,
you have mentioned a three transistor design with less output impedance, I am very interesting in it. I have probed your design with BD140&BC337 and it works fine without parasitic oscillation, but if I want to have real low output impedance, it needs a lot of current.
Aim of circuit is the analog supply of a WM dac, it sounds better with very low impedance power supply. Have you any measurement data about noise increasing / decreasing? What is your opinion about this?
Old 10th May 2014, 04:48 PM   #705
keantoken's Avatar
The BC3x7 is a very low-noise transistor. I don't expect the Kmultiplier to have much more noise than this transistor. The noise will be buried in ripple (~200uV-1mV) unless the input ripple is very low.
I have a 3-transistor version but I haven't tested it yet.
Old 17th May 2014, 06:17 AM   #706
Sunami is offline Sunami  Indonesia
Default KMultiplier for Preamp Power Supply
Hi Kean,
I would like to replace my PS Audio Preamp "Power Supply" with KMultiplier.
However I have some question :
1. Can I combine KMultiplier with LM-317 and LM-337 without effect to the
sound performance.
or possible to use trimmer in KMultiplier to adjust output voltage and
make same output voltage between positive section and negative section.
Please suggest your best solution.
Because my transformer 24 VAC, after rectifier and capacitor about 33 VDC.
Preamplifier need about 28 VDC.
2. Recommended Capacitor after output K-Multiplier.
3. What about snubber filter and bladder resistor.
Thank you for your help, I am beginner my question maybe funny.
Rgds,
Sun
Old 19th May 2014, 12:29 AM   #707
Any advise below combination.
Rgds
Sun
Old 19th May 2014, 02:22 AM   #708
keantoken's Avatar
Capacitors: I would use plain old Nichicon VR, because it is good and inexpensive. Many here prefer Panasonic FC for many of their projects so you may use that if you want.
Bleeder resistor: I would use a normal 6.8k after the KM for 28V.
Trimming: I suggest to increase R2 for the KM that has higher output voltage.
Snubber filter: What do you mean?
Your schematic will work. There should be at least one lytic near the output of the KM.
Old 19th May 2014, 08:59 AM   #709
Dear Kean,
Thanks and appreciated to your response.
Snubber Filter means C+R (10nF + 10R) after KM.
You mean by increase R2, I not need to use voltage regulator to have 28 VDC of output KM.
Rgds,
Sun
Old 19th May 2014, 10:52 AM   #710
R.I.P.
Sun,
why regulator then Multiplier?
Usually we see Multiplier before the next circuit.
regards Andrew T.
Keantoken's CFP cap multiplierHide this!Advertise here!
Vbe multiplier - bypass cap Donk Solid State 7 22nd January 2008 01:55 AM
Question(s) about CFP. Justcallmedad Solid State 94 20th September 2005 10:08 AM
cap multiplier or not? PederBass Solid State 13 23rd March 2004 06:26 PM
Cap. multiplier or regulated supply ? Buhl Pass Labs 1 8th October 2003 10:51 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
