Keantoken's CFP cap multiplier
Old 18th April 2014, 12:10 AM   #641
keantoken is offline keantoken  United States
keantoken's Avatar
The 45V+ version is no different in its output impedance than the original version.
The Kmultiplier's output impedance is comparable to that of large electrolytics. This basically means that if you put a 1000-2200uF lytic at the output, supply impedance will be halved. Another and it will be cut in third. So, wherever you want to end up, let this be your guide. Any lytic smaller than 470u probably won't have much of an effect unless it is closer to the circuit than the KM. A large film cap however will have low enough ESR to be an improvement in the ultrasonic range.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 18th April 2014, 12:15 AM   #642
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I am doing the tube version, so B+ of 340.
...Shape the sound , Man!
Old 18th April 2014, 12:39 AM   #643
keantoken's Avatar
Both the lytic and film cap will probably be helpful for the tube version. If I went with just one I would use the film cap.
Old 18th April 2014, 12:59 AM   #644
buzzforb's Avatar
I was considering this versus the Salas shunt for no other reason than cost and total junctions, but with the caps, the cost is higher. I am still curious if I will like it more, as the there are less transistors involved in the signal. Simple minded, i know, but just a theory.
Old 18th April 2014, 03:14 AM   #645
keantoken's Avatar
I can't say either way. But if you build the KM first to find out, you'll have them available when you use the shunts. In any case I'm curious what your result would be.
Old 18th April 2014, 05:56 AM   #646
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Originally Posted by AndrewT View Post
60mm is longer than my thumb.
That puts 200mm in as a long dimension.
0.5nH to 1nH per millimetre of trace/wire adds up very quickly to raised HF impedance.
That is a new formulation of a Rule of Thumb
Ā la recherche d'un son perdu
Old 18th April 2014, 08:14 AM   #647
R.I.P.
That took a while, but you got there.
I am not known for humour mongering, but sometimes I surprise even myself.
regards Andrew T.
Old 18th April 2014, 02:12 PM   #648
buzzforb's Avatar
Kean,
Could you walk through the forumula for figuring the Zo of the K multiplier if it will be supplying a B+of 340mV@20mA. I have tried using the explanation on the site, but I am misunderstanding something, it seems.
For instance,
"Q1 is biased into it's most linear range by R1. So Ic(Q1) is roughly .68/47=~15mA. This is a bit low to accommodate for a nominal max of 5mA Ib(Q2)."
Is there conflict in this statement? Its 15mA, but a bit low for nominal 5mA for q2 base?
Old 20th April 2014, 11:33 PM   #649
Triodethom is offline Triodethom  United States
Triodethom's Avatar
Rule of thumb was refering to width I believe about 25mm or 1inch approx. Still it adds up fast at higher freq.s .
Old 21st April 2014, 08:02 PM   #650
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Been using Kmult behind Salas BiBs in my headphone amp with great results for a long time now. Sound is more uniform without harshness but keeping all the detail and "byte".
Tried to use the same behind FdW shunts on the paradise and got bad sounding high frequencies. seemed like distortion. Scoped it and found that I had ultra high freq modulations.... oscilations maybe.
Now I am experimenting it behind Salas folded and it works very well.... ripple comes down from 360mv to 80mv just before entering the shunts and I hear no distortions at all. Can not give a good subjective listening impression because I only have one channel running with the kmult.
Will now build another one and report the results latter.
RC
Keantoken's CFP cap multiplierHide this!Advertise here!
Vbe multiplier - bypass cap Donk Solid State 7 22nd January 2008 02:55 AM
Question(s) about CFP. Justcallmedad Solid State 94 20th September 2005 11:08 AM
cap multiplier or not? PederBass Solid State 13 23rd March 2004 07:26 PM
Cap. multiplier or regulated supply ? Buhl Pass Labs 1 8th October 2003 11:51 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
