Keantoken's CFP cap multiplier
TNT
Joined 2003
Built it: yes.
Start it: No.
Alex, thanks for building board & confirming board working OK.
What's your plan to power with these boards?
I'm using this first PCB to power-up my Linkwitz filter for subwoofer. I already used these devices in Salas Raw DC for his FSP with an excellent results.
It dropped my V ripple substantially and Salas Phono with about 72 dB is very quite. Also, I used it in my J-Mo Mk II Headphone amplifier. Also with perfect result. Now I have 11 boards left and I plan to use them widely in my projects, but definitely and only when its really needed. That you for these nice PCBs.
P.S. I can find you Raw DC with snubbers on DertyPCB. Is it ready?
TNT
Joined 2003
Finally have 2 KCCMs working. One for the DAM R2R DAC and one for JG buffer stage. The DAM draws:
Positive Rail: .18A, 10V
Negative Rail: 0.06A, 10V
Total: 2.4W
so maybe one should bleed the minus side to get the output imp down?
Already they seem to have improved my sound and taken away a little harshness in the top and also made for a more solid foundation in general. Very nice!
Thanks you for your contributions.
The output circuit uses intentional feedback to reduce output impedance. The filter circuit has no intentional feedback. It doesn't have to have global feedback to be a filter, you can just use one transistor and that removes the feedback and the low output impedance (and gives you an ordinary C-multiplier).
Max input ripple before saturation: 1.5V pk-pk (0.46Vrms on an AC multimeter)
It means k-multiplier filters cant be used if there is a 2V drop across the filter capacitors ?
Right now i am powering 8 opamps via 337/317 regulators. Transformer is 6VA, two windings.
WITH no LOAD: +/-31V DC before the regs.
WITH LOAD: 28.8V DC before the regs.
Note: Load is constant (34mA from the Regulators output to the opamps)
Is it good idea to try k-multiplier filter in that setup ?
