Keantoken's CFP cap multiplier
Old 27th June 2013, 03:15 AM   #401
keantoken is offline keantoken  United States
keantoken's Avatar
I can work on it, but I've run out of 2SC5171/A1930, and I've only got a few BC3x7-40 (OnSemi) left. If someone can send me some of these I'd be really grateful, but otherwise I can't say when I'll be able to work on improvements to the Kmultiplier, and other things.
If you are curious whether devices like the 2SB649/D669 or BD140/139 or whatnot will work, I'd be glad to test them if you can send some my way. Note that the BD140/139 are different depending on which manufacturer. If you send me something, be sure to say what company it came from (as well as retailer) otherwise the results may be deceptive.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 27th June 2013, 02:50 PM   #402
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
For x=3 , Mouser can send you twelve thousand of them, image below.
They also have 4,500 2SC5171's from Toshiba, and 2,600 2SA1930's from Toshiba.
Mouser ships from Ft. Worth, Texas so the postage ought to be inexpensive.
Old 27th June 2013, 03:04 PM   #403
keantoken's Avatar
I've used mouser tons of times. Money is precious though, so like I said, unless someone is really interested in my ideas, it will have to wait indefinitely so I can order in a large batch.
Old 27th June 2013, 03:11 PM   #404
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I can send you all kinds of transistors, also BC327, 337.
Send me a PM with your snail mail address and e-mail address.
It may be hard though for me to exactly find out the manufacturer and where i bought them. i have the usual suspects though.
Old 30th June 2013, 10:41 PM   #405
HiFiNutNut is offline HiFiNutNut  Australia
Originally Posted by jackinnj View Post
This is the result found when 13 regulators of different manufacturers (or designs which have appeared in DIY circles via The Audio Amateur or Web) (The outlier is the Burson, or the Euphonic Regulator . The Linear Tech off the shelf devices are very,very good.
Later, an observation was presented that the harmonics a regulator can impress on the supply rails played a role in the subjective listening test. The simulations don't exactly replicate reality, but they come close when the devices were checked out using the AP Test Set.
I've ordered the parts to look at the K-Multiplier with the AP Test Set, In the interim here's an FFT simulation of the K-Multiplier as it appears on the web (red), the 820 uF cap on its own (yellow) and the Jung regulator with AD825 error amp. All were loaded the same, and injected with a 20mA perturbation current:
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
Folks are throwing regulators our way for another taste-test.
That is very interesting. I guess that you might find it similar to the Teddy reg, because the KM is not a regulator and it does not regulate. On the other hand, the KM output has lower impedance than the Teddy.
The reason I can use the KM successfully is because the KM doesn't mind any capacitors (low ESR) and any amount of capacitance at its output therefore I can use it safely without worrying about the output inductance and decoupling capacitance forming resonances. The absolute vast majority of the regulators would fail this test.
In other words, the way I expect KM to work is to have a huge amount of capacitance at its output (currently at 4 x 2,2000uF Rubycon ZL with Z=0.015R each at 100kHz) to provide a low impedance at high frequencies.
If you are going to test the KM performance, I suggest puting a large amount of low ESR capacitance at the output of KM, to make your comparison fair, as I see this is the way the KM should work. It is also important to draw at least 100mA current at the KM's output to make your test result meaningful.
Old 30th June 2013, 11:03 PM   #406
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Yes, it needs an input cap. I should have added that to the schematic.
2SA1930/C5171 is important for PSRR. Any other choice is a gamble.
looks like I was lucky when I mounted bridge and smoothing caps close, together with multiplier
Old 30th June 2013, 11:53 PM   #407
keantoken's Avatar
Maybe so. I always assumed an input cap would be used, so I haven't tested it much without one. Source inductance can cause most regulators to oscillate. I know why this is, but I don't know if I can eliminate that problem entirely and still have a simple circuit. WELL, the simplest fix is an input cap... Need I say more?
With an extra transistor and a few diodes, I can extend PSRR to over 80db I think. I would need another transistor to improve output impedance but that may not really be desirable.
Old 2nd July 2013, 04:13 AM   #408
I think load regulation is what we need while line rejection is NOT important at all, explained below.
If we use a LM317/337 as pre-regs, which give 60dB+ line rejection, combined with the KM we have over 120dB line rejection. That is before the load, which would have another 60dB to 120dB rejection for an opamp. I see no reason to have any more.
However, more load regulation is needed, because the LM317/337 or the KM have around 30-55dB load regulation only.
Note that line rejection is accumulative. So we can cascade two stages and double the amount of line rejection.
However, load regulation is NOT accumulative. So we really have 30 - 55dB load regulation only, and the rest relies on the mercy of the PSRR of the load, and for an average opamp, it may be 60dB at 20kHz.
Old 2nd July 2013, 04:49 AM   #409
keantoken's Avatar
How many extra effective inches of output inductance is too much?
Old 2nd July 2013, 11:21 AM   #410
R.I.P.
Originally Posted by HiFiNutNut View Post
.................If we use a LM317/337 as pre-regs, which give 60dB+ line rejection, ..................
over what range of frequencies?
If the reg let's through most of the HF stuff, then the next reg will let through most of that same HF stuff.
regards Andrew T.
Keantoken's CFP cap multiplierHide this!Advertise here!
Vbe multiplier - bypass cap Donk Solid State 7 22nd January 2008 02:55 AM
Question(s) about CFP. Justcallmedad Solid State 94 20th September 2005 11:08 AM
cap multiplier or not? PederBass Solid State 13 23rd March 2004 07:26 PM
Cap. multiplier or regulated supply ? Buhl Pass Labs 1 8th October 2003 11:51 PM
Copyright ©1999-2019 diyAudio
