Keantoken's CFP cap multiplier
Old 25th April 2020, 06:23 PM   #1151
prasi is offline prasi  India
ANALOG DESIGN
prasi's Avatar
thanks keen,
tried with a 500 ohm load, still same thing. grounding arrangement can be seen in the below image.
clean ground (317/337 and CMX share a common ground point near the leds.
rectifier and bulk caps are far upstream.
I will try replacing the 337/327 and see..
my load demand is quite low, ESP HPA. In that case will mje15033/32 pair be ok?
regards
prasi
My revamped site https://sites.google.com/site/analogdesign1234/
Old 25th April 2020, 06:36 PM   #1152
keantoken is offline keantoken  United States
keantoken's Avatar
That layout looks okay. I notice I didn't recommend the 15033/32 for the Kmultipliers. That is likely because I didn't have any to test, or if I did, they were not stable.
I would suggest finding a way to load the kmultipliers over 25mA, or switching to D44/45H11G. You can also try switching to BC5xxC for the TO92s, that has also worked before.
Just to make sure it is not another problem, please give me the voltage at each transistor pin.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 25th April 2020, 06:58 PM   #1153
keantoken's Avatar
For everyone else: I do have Kmultiplier boards, but I got them from the fab without being cut apart, and I can't find my shears. Until I do, you'll have to get 4 at a time and cut them apart yourself.
Old 25th April 2020, 09:09 PM   #1154
ANALOG DESIGN
prasi's Avatar
Thanks kean, I will put them to good use in next project with recommended transistors ( an AKSA class A HPA) . meanwhile for this esp hpa , i built up a simple crc+lm317/337 as per Power Supply for Preamps , works fine for the purpose.
regards
prasi
Old 1st July 2020, 02:03 AM   #1155
proid is offline proid
Hi Keantoken, i want to use some sot223 transistor for space saving so can i use bcp53/56, pzta06/pzta56 in place of big transistor?
Old 1st July 2020, 03:06 PM   #1156
keantoken's Avatar
As long as the transistor can support the power dissipated, it is worth a try. If the transistor is not suitable you will have low PSRR or it may oscillate.
  Reply to this post
Keantoken's CFP cap multiplierHide this!Advertise here!
Vbe multiplier - bypass cap Donk Solid State 7 22nd January 2008 01:55 AM
Question(s) about CFP. Justcallmedad Solid State 94 20th September 2005 10:08 AM
cap multiplier or not? PederBass Solid State 13 23rd March 2004 06:26 PM
Cap. multiplier or regulated supply ? Buhl Pass Labs 1 8th October 2003 10:51 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
