Keantoken's CFP cap multiplier
Old 18th June 2019, 09:55 PM   #1141
eris is offline eris  United States
Send a message via AIM to eris
Originally Posted by keantoken View Post
It is just a 6db per octave slope.
I try to specify transistors so that PSRR will be high up to the maximum current, I don't rate it just based on power dissipation limits.
BTW: Somehow I doubt this, but is it possible to run multipliers in parallel to increase current?
Don't believe everything you think!
Old 18th June 2019, 10:15 PM   #1142
keantoken is offline keantoken  United States
keantoken's Avatar
You could potentially use parallel slave transistors to do this but then you might start to overload Q1. The whole circuit needs to be reexamined.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 24th June 2019, 03:34 PM   #1143
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Also, the ancient Jean Hiraga from 'Audiophile (a magazine in France) said that the Darlingnot couple used will easily be prone to very high frequency odscillations.
Ā la recherche d'un son perdu
Old 24th June 2019, 09:24 PM   #1144
I think it's a Sziklai complementary pair. From my reading I remember several articles that say poorly engineered Sziklai pairs can be unstable, but with proper attention to detail it's not an issue.
Keantoken's CFP cap multiplierHide this!Advertise here!
Vbe multiplier - bypass cap Donk Solid State 7 22nd January 2008 02:55 AM
Question(s) about CFP. Justcallmedad Solid State 94 20th September 2005 11:08 AM
cap multiplier or not? PederBass Solid State 13 23rd March 2004 07:26 PM
Cap. multiplier or regulated supply ? Buhl Pass Labs 1 8th October 2003 11:51 PM
Copyright ©1999-2019 diyAudio
