Keantoken's CFP cap multiplier
Old 22nd November 2017, 04:26 PM   #1101
keantoken is offline keantoken  United States
keantoken's Avatar
Good catch. The input C grounds form a big transmission loop for rectifier pulses. The ground plane would not help with audio frequency rectifier harmonics. Trafo CT should be joined at the terminal blocks and then go to star ground.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 22nd November 2017, 05:02 PM   #1102
prasi is offline prasi  India
prasi's Avatar
thanks Andrew /Keantoken,
Yes, it was the sch. that mislead. Its should be similar to the LM317/337 that I did a while ago.
I am getting some boards made for myself and for anyone who is interested, if I may have Keantoken's permission.
regards
Prasi
My revamped site https://sites.google.com/site/analogdesign1234/
Old 22nd November 2017, 07:05 PM   #1103
R.I.P.
That layout is wrong.
The Centre tap (CT) goes to the junction between the first two smoothing capacitors.
regards Andrew T.
Old 22nd November 2017, 08:17 PM   #1104
av-trouvaille is online now av-trouvaille  Netherlands
Can someone please explain whether it is better to have a regulator before, or after the K-multiplier? Up to now, I have used the K-multiplier before the regulator, in order to make life more easy when regulating.
Old 22nd November 2017, 08:22 PM   #1105
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Placing the K-mx after the reg means you lose the low Zout of the reg.
Jan
Old 22nd November 2017, 09:29 PM   #1106
keantoken's Avatar
That makes the most sense, but there is one exception. The high inductance of chip regulators can cause noise peaks and resonances in the audio spectrum. The question is whether this is more audible than .02-.1 ohm output resistance of the KM.
Old 23rd November 2017, 12:20 AM   #1107
jameshillj is offline jameshillj  Australia
Jeez, Andrew - the layout is wrong - God has spoken - you're sent down for 20 years - you've failed - you're out!
Perhaps you could express your alterations in a more positive, diyAudio way - simply indicate where he might be able to improve the design, in your opinion, to achieve a better result - it called 'encouragement'.
Now, I might be mistaken but the 78** and 79** regs don't offer a uniform impedance across the freq and power range and also aren't low noise across the same range either, if I remember correctly, yes?
For an amplifier like the HPA-1, this way is (IMO, again) a preferable alternative even if the figures indicate otherwise - some headphone amps do use regulators last with good results, but I find there's a better sound with the C-Mx and K-Mx on the output -
Like a lot of things to do with headamps/phones, you have to try it out to find which one suits your 'taste'
You'll note that there has been no/little mention of capacitor selection here yet - that'll produce some prejudices, no doubt - early days ...
Old 23rd November 2017, 01:58 AM   #1108
prasi's Avatar
I think I need my sleep. doing two layouts (this PSU on one side and a 500W subwoofer amp on the other ) simultaneously I seem to be making lot of errors.
forgot C1+ existed.
Old 23rd November 2017, 05:00 AM   #1109
prasi's Avatar
Oh, got it. The names c1+ and c1+1 although location is correct on sch , are exchanged on the layout on the positive rail.
A small break always helps.
Old 23rd November 2017, 08:33 AM   #1110
R.I.P.
Prasi,
your schematic is going to mislead you into making connections in the wrong places.
The centre tap of the transformer must connect to the junction between C1+ and C1-
Originally Posted by keantoken View Post
Good catch. The input C grounds form a big transmission loop for rectifier pulses..................
Perhaps you could express your alterations in a more positive, diyAudio way - simply indicate where he might be able to improve the design, in your opinion, to achieve a better result - it called 'encouragement'.....................
I did !
both Prasi and KeanT acknowledged that the schematic is misleading. In that first post I described that the CT must go to the first smoothing capacitors (named C1+ & C1-). KeanT then goes on to describe the problems as aerial loops emitting EMI.
regards Andrew T.
Keantoken's CFP cap multiplierHide this!Advertise here!
Vbe multiplier - bypass cap Donk Solid State 7 22nd January 2008 02:55 AM
Question(s) about CFP. Justcallmedad Solid State 94 20th September 2005 11:08 AM
cap multiplier or not? PederBass Solid State 13 23rd March 2004 07:26 PM
Cap. multiplier or regulated supply ? Buhl Pass Labs 1 8th October 2003 11:51 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
