Keantoken's CFP cap multiplier
Old 23rd August 2017, 05:51 PM   #1011
keantoken is offline keantoken  United States
keantoken's Avatar
Using the 1381/3503 is sort of a gamble. I really don't know how that will work out. Do you have 2SC4793/A1837?
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 25th August 2017, 08:05 PM   #1012
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Thank you so much
Can I route C28, C29 and C15 grounds separately to -GND ?
RC
Old 25th August 2017, 08:21 PM   #1013
nhinstruments
RCruz's Avatar
2SC4793LB-TF3T - Power Transistor 230V 1A
2SA1837LB-TF3T - Power Transistor -230V -1A
Profusion has the 2SC4793/A1837 parts
RC
Old 25th August 2017, 08:26 PM   #1014
nhinstruments
RCruz's Avatar
I have rearranged the layout... now C15 gnd goes to C29 GND and than to -GND.... is this ok ?
RC
Old 25th August 2017, 08:47 PM   #1015
keantoken's Avatar
Those transistors are from UTS, not Toshiba. I don't know how well they meet the original spec.
Looks like C13 and C11 are swapped.
It looks like KM grounds are not routed with the KM outputs, which is not good EMC practice but may be a non-issue.
Old 25th August 2017, 10:17 PM   #1016
nhinstruments
RCruz's Avatar
Eagle yes you got thank you, I will swap the caps values.
You mean I should place the KM grounds over the KM rails ?
RC
Old 25th August 2017, 10:29 PM   #1017
keantoken's Avatar
That would be ideal, to reduce the loop area between rails and ground.
Old 26th August 2017, 12:08 AM   #1018
keantoken's Avatar
It really depends on the layout, I think the most important thing is that there is a short path from the driver collectors to the zobel and drain grounds. So much of this is context-dependent, I can only make the most general comments, and I still may be wrong.
Old 26th August 2017, 10:27 AM   #1019
nhinstruments
RCruz's Avatar
Originally Posted by keantoken View Post
The decoupling caps next to your lytics should be around 2.2uF or larger not to resonate. 5mm caps up to 10uF are available.
I was convinced the KM could support small films at the input and output without fear of oscillation.
The change you propose is to avoid oscillation or to not create other type of nastiness ?
RC
Old 26th August 2017, 11:03 AM   #1020
keantoken's Avatar
It is just my suggestion to prevent the film caps from resonating with the lytics. It has nothing to do with oscillation. No regulator can prevent this. But if you have found some kind of decoupling that you prefer by experience, you don't necessarily need me to justify it.
Keantoken's CFP cap multiplierHide this!Advertise here!
Vbe multiplier - bypass cap Donk Solid State 7 22nd January 2008 02:55 AM
Question(s) about CFP. Justcallmedad Solid State 94 20th September 2005 11:08 AM
cap multiplier or not? PederBass Solid State 13 23rd March 2004 07:26 PM
Cap. multiplier or regulated supply ? Buhl Pass Labs 1 8th October 2003 11:51 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
