Keantoken's CFP cap multiplier
Keantoken's CFP cap multiplier Please consider donating to help us continue to serve you.
Old 16th May 2017, 12:27 PM   #991
Michael Mik is offline Michael Mik  Germany
Well, but I do not find C5 in the above mentioned schematic. Mmmhhhh
Old 16th May 2017, 12:32 PM   #992
keantoken is offline keantoken  United States
keantoken's Avatar
I meant C5 on the PCB.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 16th August 2017, 12:19 PM   #993
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Originally Posted by keantoken View Post
I still doubt Rbb is an issue (but if it is we'll figure it out).
Hfe for Q1 and Q3 should be at least 200 or higher preferably. If it is high enough, we can change R2 to 10k for better bass (if that's even necessary)...
- keantoken
Can i do this in the high voltage version ?
RC
Old 16th August 2017, 12:59 PM   #994
keantoken's Avatar
No, sorry. I usually set the values as high as I can anyways.
Old 16th August 2017, 04:33 PM   #995
nhinstruments
RCruz's Avatar
Thank you Kean
I am planning to use the high voltage version as ripple killer for the front end of my power amp.
It will feed the IPS and VAS because I am not sure if it can also be used to feed the driver stage.
The IPS plus VAS run at 16mA so I added a shunt resistor in the output of the kmult just to increase current pull to 40mA.... Is there a better way to do it ?
RC
Old 16th August 2017, 04:39 PM   #996
nhinstruments
RCruz's Avatar
My sim:
RC
Old 16th August 2017, 05:44 PM   #997
keantoken's Avatar
I think that should be fine. For this amp there should be no problem running the drivers from the KM.
Old 16th August 2017, 06:24 PM   #998
nhinstruments
RCruz's Avatar
Thank you Kean
Would you elaborate on this ?
Why, in this amp you state there should be no problem feeding the drivers with the KM ?
Are there any issues if I try to use the KM feeding the drivers of a differnt kind of power amp ? Example, would it be suitable even if the output stage was not made with laterals ?
RC
Old 16th August 2017, 07:19 PM   #999
keantoken's Avatar
The drivers are not really loaded by MOSFET gates, so there will not be much current demanded from the KMs. For a BJT output amp the situation could be different.
Old 16th August 2017, 07:29 PM   #1000
nhinstruments
RCruz's Avatar
So even with the need to charge the mosfets input capacitance there should be no issues.
I will see if I can introduce these mods on my layout.
RC
Keantoken's CFP cap multiplierHide this!Advertise here!
Vbe multiplier - bypass cap Donk Solid State 7 22nd January 2008 02:55 AM
Question(s) about CFP. Justcallmedad Solid State 94 20th September 2005 11:08 AM
cap multiplier or not? PederBass Solid State 13 23rd March 2004 07:26 PM
Cap. multiplier or regulated supply ? Buhl Pass Labs 1 8th October 2003 11:51 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
