high current inductors from copper tubing?
Old 17th October 2009, 08:21 PM   #1
star882 is offline star882  United States
star882's Avatar
Default high current inductors from copper tubing?
For high current power supply circuits like a fast charger for an EV, could inductors be made by coiling copper tubing? It is cheap, commonly available, and low resistance. They can be cooled by pumping a nonconductive fluid like mineral oil or even air through them and their cross section makes more efficient use of material after accounting for skin effect. They can be painted if insulation is required.
Would the amount of tubing needed to get useful inductances be impractical? What would be the current rating of different sizes of tubing?
For example, a homemade EV charger contains two 150uH, 50A inductors. They cost about $27 each. How many feet of tubing at what minimum size would be needed to make equivalent inductors and how much cheaper would they be? Assume overall size is of little concern, like if the charger is designed to be installed in a garage.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 17th October 2009, 09:16 PM   #2
Andrew Eckhardt is offline Andrew Eckhardt  United States
Fluid cooled and tubular coils don't make much sense unless you are dealing with extremely high power (more than a 200A residential service provides) or RF... or maybe you'd be looking for very high power density, but you said you don't care about that. The whole idea of green transportation means that high efficiency figures heavily into the deal across the board, meaning that you'd seek to minimize loss before giving up and simply increasing dissipation capability. $27 bucks for single quantity parts to build a DIY electric car charger seems well in-range, not knowing anything else about your project.
Old 17th October 2009, 09:35 PM   #3
star882's Avatar
20' of 1/4" tubing only costs $12 at Lowe's. I think it would handle 50A just fine with just passive cooling, but how much of that tubing would be needed to make a 150uH inductor?
Old 17th October 2009, 09:41 PM   #4
Far less than 20ft. (I take that back) Assuming you're winding an air core solenoid, the formulas are available via google. The length required will depend on the geometry of your choosing.
Old 17th October 2009, 09:48 PM   #5
Conrad Hoffman is offline Conrad Hoffman  United States
Tubing makes sense for RF, but my guess is your frequency isn't high enough for it to be a good choice. You might be better off with plain wire or maybe heavy litz wire optimized for the frequency in use, plus an *air gapped* core to keep the efficiency super high.
I may be barking up the wrong tree, but at least I'm barking!
Old 17th October 2009, 09:59 PM   #6
PB2 is online now PB2  United States
PB2's Avatar
Hi Star,
Are the ones that your looking at air core?
I think your talking about a lot of turns for 150 uH air core.
Is the schematic for this design online? I'm curious to take a look at it.
Old 17th October 2009, 10:10 PM   #7
rdf is offline rdf  Canada
rdf's Avatar
Standard practice in AM tower matching and phasing networks.
Ears aren't microphones.
Old 17th October 2009, 10:16 PM   #8
star882's Avatar
It's not my design but you can find it at DIY Open Source EV Charger - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com .
I'm thinking air core as nothing special would be needed, but other materials can be used if they are easily available to the average DIYer.
And what would the current rating be for 1/4" tubing under passive cooling?
Old 17th October 2009, 10:18 PM   #9
PB2's Avatar
This .pdf doc from the ARRL might help, but notice that the air core coils are around 10 to 20 uH:
www.arrl.org/tis/info/pdf/9708033.pdf
Old 17th October 2009, 10:20 PM   #10
infinia is offline infinia  United States
infinia's Avatar
I would look at copper braid and powered iron cores (distributed gapped iron) depending on core choice and frequency, the cores losses could rival the Cu loss.
high current inductors from copper tubing?Hide this!Advertise here!
Copper foil versus wire in inductors klitgt Parts 45 2nd November 2017 10:26 AM
Good Source for high current Inductors?? Zero Cool Pass Labs 5 13th November 2004 11:36 PM
copper foil inductors dave k Multi-Way 1 1st June 2003 12:02 AM
Copper foil inductors. JoeBob Multi-Way 5 22nd April 2002 06:39 PM
Copyright ©1999-2019 diyAudio
