The simplistic Salas low voltage shunt regulator
diyAudio Chief Moderator
Joined 2002
Where can I buy, is to be installed at the probe, how much cost?
Its usually in the probe accessories when buying a new probe. Along with channels color rings & square wave alignment plastic screwdriver. But you can make from wire or maybe find on line as "ground spring". Example: PK1-5MM-118 Teledyne LeCroy | Test and Measurement | DigiKey
It goes on like this:
rigol-ds1054-needle-spikes-true-or-false
