I tried to make a PCB for capacitance multiplier supply .
The first time that I we done PCB so if you can tell me whether it is O.K.
PAD 1,2,3,4, are inputs from the transformer ,PAD 8 is + , PAD 5 is - , and between C4 C7 is GND .
If you're using this for high currents, your traces are too narrow. Especially the main trace that goes to the 10,000uf cap. Try to use 2oz copper and set the trace at a minimum of 0.200 inch 0.25 or 0.30 would be better.
Ken
