Simplistic Mosfet HV Shunt Regs
Thread Tools
Old 18th November 2020, 08:40 PM   #6301
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Maybe EL84 trioded which is in a less microphonic bottle when at line gain
Old 18th November 2020, 09:57 PM   #6302
merlin el mago is offline merlin el mago  Europe
merlin el mago's Avatar
Now I'm listening, with the new Vin-Vout difference sounds very good, possible needs more difference to sound still better.
Old 18th November 2020, 10:09 PM   #6303
Salas's Avatar
Maybe now has clearer DC difference between Q2 and Vout? Maybe the IXYS Q1 needs particularly more Vin-Vout to work well because its a 1000V tougher part than DN2540?
Old 18th November 2020, 10:12 PM   #6304
No doubt, my subjective opinion is that 5687 SE sounds a lot better with SSHV2 as I always suspected. Also Moglia's is top notch SQ.
Old 21st November 2020, 09:03 PM   #6305
Changed Q1 for DN2540 also a new power transformer with more voltage and all is going on OK.
Old 21st November 2020, 09:18 PM   #6306
Salas's Avatar
Are the Q1 Q2 source pin voltages bit higher than Vout voltage now?
Old 22nd November 2020, 02:39 PM   #6307
No.
Old 24th November 2020, 03:59 PM   #6308
Salas finally set the BiB to 12.6V to power the 5687 heaters.
  Reply to this post
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Thread Tools
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 04:59 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
