Simplistic Mosfet HV Shunt Regs
Old Today, 11:15 AM   #6121
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by morpheous View Post
Here's my SSHV2
Sink in sink? First time I see Russian doll sink Does it have thermal paste between sinks? Needs it.
Old Today, 11:21 AM   #6122
Salas's Avatar
Originally Posted by euro21 View Post
This type preamps need ca. 15-20mA / channel, so with 25-30mA shunt current the power supply load is ca. 50mA /channel.
One SSHV2 (90-100mA) is also OK for both channels.
Lite Audio suggest 7815 and 7806 (7805 and and one diode from reference pin to ground) stab. for heaters.
http://www.lite8.com/product.php?action=723
I suggest he should measure a channel's rail consumption via voltage drop across 1 Ohm series resistor between SSHV2 and B+ input. Knowing exactly where to set CCS in his case is saving precious voltage drop in his rectification section.
Old Today, 01:22 PM   #6123
morpheous is offline morpheous  Italy
morpheous's Avatar
Send a message via Yahoo to morpheous
I know it's exaggerated, the pasta served me to facilitate the assembly.
Old Today, 01:24 PM   #6124
morpheous's Avatar
I will also test with the L-adapter. What should I use for the turntable to replace that 16V power supply?
Old Today, 02:16 PM   #6125
Salas's Avatar
That's AC/AC adapter. Don't feed DC to the turntable. It has 90deg op-amp low voltage synchronous motor drive generators inside on a pcb. Some tables have DC motors but not this one. That board rectifies and filters the incoming 16V AC for its own use. Bigger better 16V AC transformer maybe, but I don't know if of any benefit.
Old Today, 03:15 PM   #6126
morpheous's Avatar
True, I only realized it now AC / AC Adapter.
As soon as I can I finish mounting pre-amp and do the tests, I'll let you know.
In any case, you say will it be the case to buy a better transformer for this pre?
Old Today, 03:23 PM   #6127
Salas's Avatar
Not sure, it may play very well even with less than 260V. Tubes have tolerance range.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
