Simplistic Mosfet HV Shunt Regs
Old 17th November 2019, 09:19 AM   #6021
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Sounds pretty catastrophic. Maybe an insulation issue or a PCB issue? An arc? I don't know this green PCB you showed.
In your shoes I would either follow the whole troubleshooting procedure link going down to last components like Zeners and trimmer, after inspecting and cleaning the board thoroughly, or simply restart and build new with a clean slate but with fuses on its input and output this time. Slow blow ones of comparable value to the CC setting.
Also by using a fat Schottky diode instead of the Zener (the one near the JFET). If planing to transplant some parts, trust only those that will measure OK off board on their own with DMM and transistor tester.
Old 17th November 2019, 02:42 PM   #6022
bigpandahk is offline bigpandahk  Hong Kong
I measured the voltage at each stage again and found that when input goes higher than 230V, the voltage at C1 dropped to lower than 20V. So it should be Q1, Q2 have problem. As I don't have any more spares, need to order some and try again later.
Old 17th November 2019, 03:09 PM   #6023
Salas's Avatar
There are some IXYS HV DMOS options too. MJE350 can substitute any dead Q4 Q5 also if available locally. Lower spec option but good enough for proof testing.
Old 17th November 2019, 03:17 PM   #6024
Salas's Avatar
P.S. Also try one of those transistor testers with the ZIF socket and little LCD screen found everywhere online. They are good enough for recognizing semiconductor types, sorting out working or dead ones, comparing some parameters etc. They are very cheap and can be helpful.
Old 18th November 2019, 02:07 PM   #6025
All semiconductors ordered and will be delivered tomorrow. As per your recommendation, I bought a Chinese transistor tester at only $8.
Old 18th November 2019, 02:20 PM   #6026
Salas's Avatar
Old 30th November 2019, 09:05 AM   #6027
Hi Salas
Finally I got all the semiconductors and replaced Q1, Q2, D1 and D2 but the symphony still the same. The voltage measured at C1 goes up to 23xV then drop to 0V, input still has 26xV. Q1 became very warm >50degC.
What show I do?
Old 30th November 2019, 11:43 AM   #6028
Salas's Avatar
Clean the board very well. Remove Zeners.
Old 30th November 2019, 01:22 PM   #6029
Jallhalla is offline Jallhalla  Norway
I bought a kit for a SSHV psu a few years ago, and now I want to use it in a high output Z, cathode follower, OTL topology headphone amp with one 12au7 and one 6080 tube. I need 170v output, and have a 150v transformer. How much filtering should I use, and how do I set the right output? Could anyone help me estimate the current this amp needs?
Old 30th November 2019, 02:19 PM   #6030
Salas's Avatar
Impossible for anyone to estimate without a schematic at least. You should measure the current consumption of the client circuit with an Ameter between PSU and B+ input first. If its built and has a PSU as it is. You add 20mA to the reading for the shunt's bias and calculations. With PSUD2 software simulator from Duncanamps.com you can enter the Tx data and decide configuration and filtering of the raw DC part so it drops to 190V DCin when the SSHV2 powering the client circuit is involved.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 04:59 PM
Copyright ©1999-2019 diyAudio
