Simplistic Mosfet HV Shunt Regs
Old 22nd September 2018, 11:10 PM   #5911
merlin el mago is offline merlin el mago
merlin el mago's Avatar
What's the max difference Vin vs Vout SSHV2 can handle?
Old 23rd September 2018, 03:37 AM   #5912
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
As much max VDS and max dissipation the D-MOS on your sink can
Old 23rd September 2018, 10:59 AM   #5913
OK I will keep the 20V of difference.
Old 23rd September 2018, 06:34 PM   #5914
Q5, Q6 & D3 gone.
Old 26th September 2018, 02:31 PM   #5915
Issue fixed, thanks Salas.
Old 26th September 2018, 08:38 PM   #5916
Salas's Avatar
You also solved the AC readings issue after repairing the damage by the accidental short?
Old 26th September 2018, 09:11 PM   #5917
Yes Salas.
Old 23rd October 2018, 07:07 PM   #5918
widi is offline widi  Spain
widi's Avatar
Default sshv 2
Hello, Mr. Salas,
Some time ago I built my stage phono which I am very happy, but I have a buzz (photo of the oscilloscope at the end of the phono stage) around 75hz I use the sshv2, which works well for me or that, I adjust both tension and the current, the operating voltage is dl phono stage is 255 volts and the current is adjusted to 35ma. Attached photos of the phomo stage and psu.
Could it be a malfunction of sshv2 that produces such noise?
Old 23rd October 2018, 07:32 PM   #5919
Salas's Avatar
Hello
Was it there before or it recently appeared? Can you also find it when probing the rail? Use AC scope coupling, 1:10 probe setting and short wire ground probe tip accessory for that. It can be intereference or ground loop. Although 75Hz is a weird frequency to be hum loop.
Old 23rd October 2018, 07:57 PM   #5920
widi's Avatar
Default sshv 2
Originally Posted by Salas View Post
Hello
Thanks for answering, the noise was already in the first moment that I started the phono stage.
When reviewing the ssvh 2 output with the oscilloscope I can not see anything alarmingly, attached screenshots
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 04:59 PM
