Simplistic Mosfet HV Shunt Regs
Old 30th December 2013, 01:13 AM   #4281
king4joy is offline king4joy  Hong Kong
Originally Posted by Salas View Post
That part is a classic cascode for CCS, it was around, later I saw it analyzed in Morgan Jones 4th edition book also. A very good book to get, recommended. There is nothing much to it, you just put it where you would put an anode resistor and you turn its trimmer to fix a current. If it will not work that will only be if something is damaged. Good thing its also workable in low voltage so you can model and fix it safely. You can use an Led instead of a tube in that modeling and some 20V supply. Or a small resistor. That's all there is to it.
Salas,
I have been doing some modeling with the CCS, with 12VDC only (my line amp still at friendís place), loaded with a 620R resistor.
Playing around, with 12VDC in, loaded with 620R, the best range of the CCS I can get is 20.9mA to 5.8mA, with R3 = 1K (R4 = 500R trimmer)......further increase of R3 value did not change the range much. Click the image to open in full size.
Would you give a hint what combination of R3 and R4 I should try, to get a range of 10mA to say about 25-30mA when loaded with a VT25A please??
Thankyou, and Happy New Year!!
Old 30th December 2013, 01:20 AM   #4282
above becomes Click the image to open in full size. , I don't know how....
Old 30th December 2013, 02:08 AM   #4283
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Try at higher Vds also. 25-30V.
Old 30th December 2013, 02:35 AM   #4284
luvdunhill is offline luvdunhill  United States
luvdunhill's Avatar
king4joy: Apply Ohm's Law and you might learn a thing or two. Start with your load resistor. Also, check out SY's "Impasse" article in AudioXpress which explains how this CCS works.
Old 30th December 2013, 03:09 PM   #4285
How do I try higher Vds??
Will higher VDC input give a higher Vds??
What VDC input would you recommend to use when modeling for the real VDC input of 248VDC ??
Old 30th December 2013, 11:08 PM   #4286
Salas's Avatar
Use 30VDC or something about there. Low VDC modeling is just to verify your circuit works in safe experimenting. The real max mA you will evaluate on the real amp voltages.
Old 31st December 2013, 12:13 AM   #4287
In my amp, I am using 1 x SSHV2, TP set at 50mA, feeding a pair of these CCS, with R3 = 330R and R4 = 500R trimmer, with 248VDC, I can onlt get max about 9.0mA with the CCS.
What values for R3 and R4 should I try next please??
Happy New Year
Old 31st December 2013, 12:17 AM   #4288
Do you think I need to set the SSHV2 at higher than 50mA ??
Old 31st December 2013, 12:17 AM   #4289
Salas's Avatar
220R both I guess.
Old 31st December 2013, 12:19 AM   #4290
Salas's Avatar
If you are introducing new extra consumption at the load, reg setting should go accordingly.
Happy new year 2u2.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
