Half Bridge offline SMPS
Hi All,
I am starting to develop a 500W offline SMPS.
I would like to use a quasi resonant half bridge topology with ZVS.
This is my first design of on offline SMPS and I have some doubt:
can you please tell me what is the difference between connecting the transformer primary to GND or between the two bus capacitors? (look at the attached drawing)
In any case the transformer will be AC coupled by the small 1uF capacitor an the voltage swing across the primary will always be
+/- 160V (assuming 230V line voltage).
Are these circuits equivalents or not?
thank you
ciao
-marco
  • half_bridge.pdf
The lower one is correct: With the capacitors you will form a potential that is between the supply rails. When you switch the lower FET on, you will apply this half supply voltage across the primary winding. So the primary current starts increasing. Then you switch the FET off, wait for some time and switch the upper FET on. Now you will apply the same voltage across the primary, but in reversed direction. That means the primary current starts flowing in opposite direction.
This way you generate the alternating voltage to the secondary winding.
The upper picture cannot be correct, since switching the lower FET on wouldn't apply any voltage across the primary.
Hope this helped :)
Actually, they are equivalent - in an ideal circuit simulator kind of way. The lower one is typically used and is better in practice because there is no significant DC voltage on the coupling capacitor. The upper one wll work, but I wouldn't do it at high power.
Hi Luka,
the rest of the circuit is still to be defined.
Now I am thinking also about a double forward architecture (see attached). The two mosfets will be on at the same time and the two diodes will reset the transformer core (when the mosfets are off).
What do you think about this architecture?
thank you
  • power_stage.pdf
Two switch forward is pretty nice. It lets you use current mode control which is good. It doesn't have that many drawbacks compared to half bridge, especially at higher frequencies where you are core loss rather than saturation limited.
Using film capacitors to both rails in a half bridge might work or might create unwanted resonances between electrolytes, lead inductances and the films if you are unlucky.
