Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 18th September 2019, 01:52 AM   #1
itsikhefez is offline itsikhefez  United States
Higher end alternative to FE126En for FH3
Default Higher end alternative to FE126En for FH3
Hey all,
I was lucky enough to get my hands on one of the last FH3 flat-paks for Fostex from Dave.
Original plan was to use the FE126En but I find myself spending more on caps than on the driver, so was thinking that it may make more sense to allocate more budget to the speakers.
Amp is a 300B SET, so about 7W power.
Are there alternatives that are considered "upgrades" to the FE126En that are efficient enough for this case?
Old 18th September 2019, 02:46 AM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Most feel the Alpair 7.3 is better, i generally recommend 10w but my 5W ACAs work fine with them. And i have people happily using 2A3SE. You are giving up 4-5 dB of sensitivity, but you gain in the bass.
And of course there is the FE126eN2, where besides EnABL there are a number of steps aimed at taming the rough edges.
FE126En variants definitly want a high output impedance amp, which your 300B should be.
Your rebate will fit the FE126En or FF125wk — the latter the FExx5wk speaker with issues similar to FE126 (but a bit worse).
What are you buying caps for?
Pluvia 7 and Pluvia 7HD would fill the role as well and would likely be easier to mount.
All the mentioned drivers are nominal 4”, the FE126 4.5” so youneed to check the thru hole.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th September 2019, 07:07 AM   #3
Thank Dave.
Which issues are these? I haven't actually heard either yet.
For my recently completed 45 SET amp, quite a few components cost me more than a FE126En driver. Things like a pair of 0.1uF coupling caps, a pair of WBT RCA jacks because I liked how they mounted, tubes, etc.
In this aspect, I assume spending more on the driver will be a more cost-effective "upgrade"
Could you elaborate on what I would need to modify in order to use one of the mentioned drivers?
Old 18th September 2019, 07:24 AM   #4
astrojet is offline astrojet
I listened to FE126en in a pair of fh3 for a year before swapping for MA MAOP7. I tried PP EL34 and EL84 and SET 45 and 2A3. For my situation, the MA drivers sounded great with both SE amps -- I definitely preferred them to the FE126en. I've also made some simple BR boxes for FF105wk that I used with the same amps. Sounded fine and would no doubt sound better in a more sophisticated box. Few meters listening distance, boundary loaded and low volumes for me, so YMMV.
Old 18th September 2019, 11:05 PM   #5
frugal-phile(tm)
planet10's Avatar
hey have some significant HF resonances which some find fatiguing.
[/quote]Could you elaborate on what I would need to modify in order to use one of the mentioned drivers?[/QUOTE]
I use the driver drawings to judge how easy it is to retrofit a driver that uses no or a different rebate.
The new Pluvia 7 basket does not require a rebate, you are looking to see if it adequately covers the 126 rebate (if not it will need filling in, but the cutout also needs to be a size that is close enuff.
Red is FE126, bue is P7.
Higher end alternative to FE126En for FH3-fe126-vrs-p7-png
Looks like the cutout migh need a touh of rasping, and the corners of the fE126 reabate would not be covered, so:
1/ fill in the rebate (messy if you use something like bondo
2/ get the router out and add sufficient rebate (at the FE126 depth) to accomodate the parts of the P7 that reach beyond the FE126 rebate
3/ nuclear option. Cut a much larger hole in the baffle and add a supra baffle
dave
Higher end alternative to FE126En for FH3Hide this!Advertise here!
recommend higher SPL alternative TB w5-1138SMF mrneedle Multi-Way 7 16th March 2015 07:05 AM
higher value volume pots.....higher output signal ???? tonequester Parts 14 23rd January 2014 02:31 AM
WTB: 10,000uf or higher 71V or higher caps, max 30mmD KevinLee Swap Meet 1 10th December 2009 01:39 AM
Is it true that the higher the BL of a subwoofer, the higher its lowest playable... 454Casull Subwoofers 16 19th March 2004 05:28 PM
Super-power amps - higher current better than higher voltage Circlotron Solid State 34 28th June 2002 05:01 AM
Copyright ©1999-2019 diyAudio
