Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 11th March 2019, 02:37 AM   #11
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Help me choose drivers for a pair of Frugel-Horn speakers
You pretty much have things sorted…
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th March 2019, 02:50 AM   #12
david45 is offline david45  Canada
Ok so in other words either one of those should yield satisfactory results, is that it?
Old 11th March 2019, 03:21 AM   #13
frugal-phile(tm)
planet10's Avatar
Alpair has greater DDR, will play a bit louder, and costs more.
dave
Old 13th March 2019, 07:43 PM   #14
chrisb is offline chrisb
That Klipsch unit does look like an attractive piece for a system with basic requirements, although with a couple of limitations in terms of inputs, etc. Couldn’t find a spec for the XO to LFE channel subwoofer output, do we assume it’s 80Hz, and with no HP on the internal amp or RCA line outputs?
When was the last time you saw a piece of audio gear you could control from your watch? Or maybe that’s a new thing soon to be ubiquitous?
As for future amp upgrades, the ACA is a very nice sounding piece, as are the Neurochrome 3886 chip based kits. Not all class D amps sound the same, nor do the higher powered ones necessarily sonically outperform lower powered class A / AB.
Technology honors no Hippocratic oath
Old 14th March 2019, 05:06 PM   #15
Thanks for chiming in, Chris.
Considering amazon is now letting them go for $150, it really is a no brainer for me.
I would assume 80hz and no high-pass feature, but I'll have to look into it when the unit arrives. Actually I might just post on the cheap and cheerful circle on audiocircle as I'm curious to know the answer now
Help me choose drivers for a pair of Frugel-Horn speakersHide this!Advertise here!
Frugel-Horn Lite for 3" drivers planet10 Full Range 236 21st January 2020 02:45 AM
Frugel-Horn Mk3 single driver horn speakers Rabco Swap Meet 3 29th May 2017 08:17 PM
Trades anyone:....my Mirage for your Frugel-Horn MK3 w/without drivers/flat pack Kenny B Swap Meet 0 29th December 2013 04:47 PM
Frugel Horn for Lowther drivers ziocalepino Full Range 8 23rd August 2012 10:33 PM
FS: Frugel-horn MK3 Flatpacks with EL70eN^2 Drivers wiatrob Swap Meet 1 27th August 2011 08:00 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
