Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 27th February 2019, 05:17 PM   #21
jdrouin is offline jdrouin  United States
Well, I've not not-tried it. I always rubbed in some water after sanding with 120, let it dry thoroughly, and then continued with 220. That's the processed advised by my wife's uncle, an experienced carpenter, who says the oil can raise the grain when it absorbs into the wood, which you don't want after sanding down with fine grit. It can lead to uneven absorption as well as sub-optimal smoothness in the end, so it's better to raise the grain before the fine-grit sanding stages. I read some other advice online that said to sand to 120, raise the grain, sand at 120 again, and then proceed to 220 and finer.
Anyway, I don't want to thread-jack anymore, so I'll try it on scrap with and without raising, and report later.
Old 27th February 2019, 05:25 PM   #22
pcgab is offline pcgab  United States
10p Monitors?
I'll have to try that, certainly worth a test on scrap.
Thank you for the insights.
Gable
Old 11th June 2019, 09:40 PM   #23
opa1 is offline opa1  United States
opa1's Avatar
Update:
I've had the CGR's running for four months now. Using the Aleph J, Topping D30,SYS passive pre and Tidal. This is a great combo. I had been on a audio upgrade for years. I don't feel the need to improve now. The CGR enclosures and the 10P drivers perform really well.
Old 12th June 2019, 03:35 AM   #24
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
10p Monitors?
Old 12th October 2019, 11:30 AM   #25
WoVe is offline WoVe  Belgium
Do you have an idea of their frequency response?
And does somebody knows how they would compare to a CGR with Alpair 12p? (Frequency, efficiency & Soundwise)
I'm looking for a FR bass reflex pair in a small room (3 &3 m) to be driven from an old B&O 610 hybride tube amp (2 & 8 Watt). This looks like a very nice option, one I might be able to realize myself. ��
This is my very first post on the forum, my apologises if I intruded in somebody elses topic ...
Old 12th October 2019, 12:27 PM   #26
zman01 is online now zman01  Bangladesh
10p Monitors?
WoVe,
From my experience, the Alpair 12P does better in a bigger box like the Super Pensil 12P. For a medium sized bass reflex cabinet in room size similar to your's, the Alpair 10P is a decent performer; again it will have better bass in a larger cabinet like the Pensil or FH-XL, but a 15-16 liter bass reflex works nicely too.
What type of music would you mostly be listening to?
Old 12th October 2019, 01:16 PM   #27
I'm mostly listening to classical and jazz music, occasionally to other music too. "Classical" as in choir, orchestra, chamber music, solo instruments (in oartucular pipe organ). Usually at low to moderate sound levels and from rather close to the speakers (around 3 m). No need for thumping bass, but lower extension would be nice.
First I was looking at the FH-familly and the pensils, but thought as it's a small room, saving some space would be better.
Old 12th October 2019, 06:42 PM   #28
frugal-phile(tm)
planet10's Avatar
10p Monitors?
A10p goes higher.lower, and has better DDR (detail reproduction). It is a little less than a dB less efficient and cannot move as much air (so can’t play as loud and can be less dynamic). I prefer the A12pw as a FR over the A12p. And as Zia says, A12p really isn’t at its best unless in a BIG box.
Bass extension will depend somewhat on you amp and how much room gain… without aid by those — in 17 litre Mar-Ken10p — est F6 below 50 Hz, F10 just above 40. The top on the A10p is what i call vintage (A6p/10p/12p all do this very well).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 13th October 2019, 02:29 PM   #29
Thank you for the responses! So for this cabinet F3 would be in the mid-50ties? (Rather standard)
I'll consider some bigger brothers/sisters of the CGR 10p as well.
Wouter
Old 13th October 2019, 02:54 PM   #30
Bigun is offline Bigun  Canada
Bigun's Avatar
10p Monitors?
Originally Posted by opa1 View Post
Update:
Hi, Id be interested to hear more about the comparison between the CGR and the pencil in terms of bass, imaging, overall feel etc. as you are the only person I know has used both enclosures
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
10p Monitors?Hide this!Advertise here!
DIY passive studio monitors + amp, mod cheap monitors? jdominicjackson Full Range 11 11th June 2014 06:29 AM
WTB: NHT M60 monitors spurzheim Swap Meet 4 28th October 2010 02:50 PM
Copyright ©1999-2019 diyAudio
