Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 21st January 2019, 07:58 PM   #11
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Fostex FE208-SOL
No opinion on the new driver except that the 3 much smaller SOLs i heard were really good.
Yes i still do phase plugs for FE20x.
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 23rd January 2019, 05:12 PM   #12
BHD is offline BHD  United States
BHD's Avatar
Send a message via Yahoo to BHD
I got the last pair.
My religion is the golden rule. The only time it's forsaken me is when I've forsaken it first.
Old 23rd January 2019, 08:01 PM   #13
BHD's Avatar
Hey Dave,
Would these work in the Dallas 2 horn? I'd love to put them into a pair of Vulcan enclosures but they'll be going into a fairly small room so unless they'd work in a room like that I'm looking at putting them in a single horn. It looks like they'd *just* fit.
Old 23rd January 2019, 08:25 PM   #14
frugal-phile(tm)
planet10's Avatar
Fostex FE208-SOL
I’d expect so.
I hope the quick selling of these limited editiond means more limited editiond to come :^)
dave
Old 24th January 2019, 05:39 PM   #15
jdappel is offline jdappel  United States
Default Vulcan and the FE208-sol
I got the second to last pair. In case this would be useful to anyone, I asked Scott about using the FE208-SOL in the Vulcan enclosures. This was his helpful reply:
Hello Joshua,
As it happens you're the second person to ask this in a few days. Short
answer is yes, acoustically speaking they should go straight into
Vulcan, although I'd shift the rear panel of the low-pass chamber back
slightly to compensate for the volume taken up by the increased magnet
size. Optimally loaded output should be solid to 40Hz with an F10 around
30Hz. Frankly, that's about as far as I'd go with a chambered back-horn;
you can go lower with one but it comes at the price of increased size
and GD, and potentially reduced linearity.
In design terms there are no ports in either Vulcan or Kirishima
-strictly speaking they have horn termini. The former is a rather more
advanced design specifically designed for boundary loading to lower the
frequency to which it's impedance matched and create both a more
efficient and linear load -it has a better-defined upper corner
frequency (acoustic low pass filter) reducing GD in the lower midband.
As such they're meant to be placed in relatively close proximity to the
front wall (and if corners are available, that's theoretically the
ideal), although like all loudspeakers the optimum position for them
will need to be established the old-fashioned way, i.e. trying it out as
only the broader aspects can be roughly predicted in advance with
reasonable accuracy; room construction materials, furnishings, exact
position, rest of system's electrical behaviour and personal taste all
come into this.
Old 25th January 2019, 04:40 AM   #16
Dave,
Do you have phase plugs that would work with the FE208-SOL?
Fostex FE208-SOLHide this!Advertise here!
Fostex (2) FE208 with (1) T90 Tweeter dalbert02 Full Range 17 18th February 2015 04:53 AM
Fostex FE208 Sigma Daze Swap Meet 0 31st December 2012 01:44 AM
Can A Current Sachiko Be Fitted with 1st Generation Fostex FE208 Sigma? mister pig Full Range 2 28th January 2010 05:14 PM
fe206 in fe208 enclosure ed2000145 Full Range 8 11th May 2009 06:42 PM
Fostex FE208 Sigma Drivers oaktsh Swap Meet 9 25th January 2009 03:43 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
