Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 29th December 2018, 08:44 AM   #11
Slam630 is offline Slam630  United States
Emailed you
Old 30th December 2018, 11:41 AM   #12
@planet10 I’m interested but I can’t decipher that alphabet soup you posted. Can you please clarify?
Old 30th December 2018, 06:24 PM   #13
chrisb is offline chrisb
Yes, Google may be able to translate between almost any two current living languages, but Davish might require the skills of a Louise Banks.
Retired from active DIY
Old 30th December 2018, 07:14 PM   #14
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Just too much stuff, almost giving it away, part 4
Slam,
I really need to get to posting pictures of these to tell the story. There is some explanation here that outlines the miniOnken nomenclature: fonken-style box nomenclature... what is with those names?
Who knew when Chris named the 1st miniOnken for the FE127 a Fonken, that we would literally have a 100+ boxes to name in the same vein.
The Woden BabyLabs have there own thread: Woden Design 3" Box Designs, Baby Labs & more
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th December 2018, 10:57 PM   #15
Thanks that helps. Any opinion on which in the list is “the best”? I know that is highly subjective but would value your opinion.
Old 31st December 2018, 01:14 AM   #16
Depends on both the specific application, and as there’s quite a range in the basic sonic signature of the range of candidate drivers, your personal taste. The latter can take longer to qualify than one might think.
Old 31st December 2018, 02:47 AM   #17
frugal-phile(tm)
planet10's Avatar
Barring Chris’ (important) points, a set that didn’t make the list till now.
The Alpair 12pWeN/A7.3eN MTMs (with external passive XOs & grills). $4k. You have to come get them.
But as i showed by recently swapping in uMar-Ken6 with A6.2MeN, any of the metal cone Alpair based boxes will sound the “same” but won’t go as low or play as loud.
dave
Old 3rd January 2019, 11:48 PM   #18
5string is offline 5string  United States
Dave, how's your driver supply? I could use a replacement pair for my Mk3 Frugal horns, grandkids couldn't resist poking my FE 126's.
Alonzo
Of all the things I've lost, I miss my mind the most.
Old 4th January 2019, 01:12 AM   #19
frugal-phile(tm)
planet10's Avatar
I have a fresh batch to put on the break-in bench… so a fresh pair would be 4 weeks or so off if i got to it right away.
dave
Old 4th January 2019, 08:47 AM   #20
Price and Paypal still the same? I would be using these with a 3 watt SET amp, would you recommend I stick with the 126's or change up?
Alonzo
Just too much stuff, almost giving it away, part 4Hide this!Advertise here!
Just too much stuff, almost giving it away, part 3 planet10 Planet 10 hifi 19 21st December 2018 06:01 PM
I need a terminal to solder stuff to. Do they make this part and what is it called? garybdmd Parts 11 13th November 2016 05:34 PM
Just too much stuff, almost giving it away, part 2 planet10 Planet 10 hifi 5 6th August 2015 12:15 AM
Stuff for sale part two (UK) jerryo Swap Meet 0 5th June 2015 05:17 PM
Just too much stuff... almost giving it away planet10 Planet 10 hifi 16 18th October 2013 12:42 PM
Copyright ©1999-2019 diyAudio
