Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 12th April 2019, 10:21 AM   #21
tamra is online now tamra  Japan
Hello jdrouin.
I have built mar-ken few month ago.
miniOnken/Fonken Picture Gallery
I painted Kakishibu on birch ply wood. Kakishibu is farmeted Kaki(fruit) juice.
Amazon.com: Turner odorless persimmon juice 500ml by Turner color
Nice vintage color and some profits.
About Kakishibu (persimmon tannin) paint
I have painted shellac on it.
I am very satisfied for the build and the sound.
Old 12th April 2019, 03:10 PM   #22
jdrouin is offline jdrouin  United States
Wow, gorgeous build, tamra! Thanks for informing us about persimmon juice. Its use as a hangover preventative as well as a wood finishing product makes it especially appealing.
And Chris, thanks for the picture with the different finishes. The natural cherry on the rightmost speaker is what I had in mind for this build, though a golden oak birch would look best in the room.
I made and glued in the paper shims for behind the drivers last night. I should be able to cut and install the wool dampening material over the weekend, and glue the cabinets together over next week.
Old 15th April 2019, 07:58 PM   #23
Today I cut and applied the wool batting. Since these enclosures are fairly small, there is very little space at the back. I left the back inch of the interior sides free of lining so as not to restrict airflow.
Also, I'm inclined not to put any lining on the back panel so as to allow for air flow into the vents. Seem OK, or should I add some?
Old 15th April 2019, 08:27 PM   #24
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
mFonken103SolT Build
You need to put a little bit on the back.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th April 2019, 08:30 PM   #25
pcgab is offline pcgab  United States
I would think you want to maintain the air flow into the vents. I could be wrong, but I would be a bit worried about blocking the vents.
Do the plans mention or show where to add the damping material?
EDIT ^^ Dave answered as I was typing, ha!
Old 15th April 2019, 08:31 PM   #26
frugal-phile(tm)
planet10's Avatar
There is room to damp out to about 1/2 way from the brace
dave
Old 16th April 2019, 03:22 AM   #27
chrisb is offline chrisb
See how much fun the trapz for smaller drivers are?
Retired from active DIY
Old 17th April 2019, 03:21 AM   #28
Thanks. That was my original plan. I will add the stuff tomorrow.
I've started gluing the side wall sandwiches in place. The procedure looks like this:
* Apply glue to the interior front edge and bottom of the assembly.
* Put the assembly in place and slowly tighten the clamps just enough that they stay put. There are 4 clamps across the front to keep the panel firmly attached to the front baffle edge, 3 from front to back to press it firm against the interior of the front baffle, and 2 from top to bottom to keep it pressed firmly to the bottom panel.
* Position the rear by lining up the joint of the vent spacer and exterior side wall with a mark on the bottom panel.
* Tighten the rearmost clamp so that the assembly wouldn't wander from the mark.
* Tighten everything else a little at a time until everything is secure.
Old 24th April 2019, 04:04 AM   #29
Over the last few days I finished gluing the sides and tops. Today I cut the big chamfers and the little 90* sides using the table saw.
First I used the router to flush-trim the tops and bottoms to the front and rear panels. That ensured that the front baffle would be square with the table surface and form the reference, since it would be run through the saw face down, holding a piece of sacrificial scrap to the trailing edge (bottom panel) to prevent tear-out. I also plugged the vents and driver holes with paper towel to prevent sawdust from blowing into the enclosures. For both the chamfers and the side cuts, I used the rip fence with the saw blade pointing away from the fence, incrementally moving it closer and closer to the stopping point. At first I would assess the workpiece visually after each pass, and then as it got closer to the stopping point used the rip distance measuring gauge to move it in 1/32" at a time. It was repetitive but easy.
The stripes on the sides are interesting -- much broader and better looking than I was expecting. So, construction is complete and they actually look like they're supposed to!
I'll post the final reveal pics in a day or two once the finishing process is complete. But here are pics of the rear wall damping and final gluing stages.
The first one shows the line where the exterior side & vent spacer meet (as described in previous post).
Also, you'll see some gaps in the interior shots. Those were a dry fit and the pieces weren't secured. Everything's accurate and airtight after gluing.
Old Yesterday, 03:37 PM   #30
Six coats of Trader Joe's French Roast; two coats of satin polyurethane.
mFonken103SolT BuildHide this!Advertise here!
Transmission Line Speaker Build using Alpair 7.3 speakers, first build. vishalk Full Range 123 29th March 2017 12:22 AM
Super Squirrel Monkey - First from-scratch tube amp build, first guitar amp build ericj Instruments and Amps 32 5th April 2016 10:28 PM
question:How to build How to build music player with tda1543 use rapspberry pi B+? gary095315 Digital Source 1 30th December 2015 07:35 AM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
Copyright ©1999-2019 diyAudio
