Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 5th February 2015, 03:27 PM   #1
RonObvious is offline RonObvious  United States
Default Stuffing for Markaudio Pensil R70.3?
My daughter sees me building speakers for my entertainment center recently and has decided she wants a pair of speakers for her upcoming birthday. OK, I'm game! We both like the idea of the Markaudio Pensil R70.3 TLs, with the CHR-70.3 full range drivers. My question is about stuffing. The plans simply say to use 0.7 lb of polyfill. I have never built TL speakers before. I understand the function of the stuffing is a little bit different than it is in a bass reflex or sealed box.
How should I distribute this 0.7 lb of stuffing? Staple it to the walls? Tease it out and suspend it with chicken wire? Attach it to the bracing? I guess I'm mainly unclear about whether the stuffing should be attached to the walls or suspended uniformly in the cavity? And should it be fluffed? Thanks in advance!
Old 5th February 2015, 04:33 PM   #2
toobhed is offline toobhed  United States
I generally use a bit less than the prescribed amount and really fluff the hell out of it for maximum expansion....play around with different amounts to your taste. My pensils also have a 2 -3 inch high x 3/4" thick ply braces just above the bottom opening, one from back to front and one from side to side....this keeps the fill from falling down into the port area.
Old 5th February 2015, 04:34 PM   #3
I also try to fill evenly between top of cabinet to bottom above braces.
Old 5th February 2015, 06:05 PM   #4
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
What Mario said.Well teased & spread evenly thru-out the box.
The purpose id to try and depress the unwanted harmonics of the pipe while leaving the fundemental to reinforce the bass. It is a balancing act.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th February 2015, 06:23 PM   #5
OK, will do. Thanks everyone!
Old 12th May 2018, 10:26 AM   #6
Dhruv Meena is offline Dhruv Meena  India
can we use alpair 7.3 in pensil r70.3
Old 15th May 2018, 06:34 PM   #7
chrisb is offline chrisb
Since it looks like the R70.3 is 1.5" deeper, but with the same height, depth and vent dimensions, if you could fashion cleating to recess the back panel, and adjust the driver cut-out / rebate, I'd think it should work.
Retired from active DIY
Stuffing for Markaudio Pensil R70.3?Hide this!Advertise here!
Pensil with 7.3 boblamont Planet 10 hifi 22 28th July 2013 04:42 AM
Stuffing a Pensil roscoman Planet 10 hifi 7 24th October 2012 03:18 PM
Cutting plans for Pensil 12 and Super Pensil zman01 Planet 10 hifi 3 24th March 2011 04:48 AM
El70 in Pensil? type Planet 10 hifi 12 11th September 2010 07:41 PM
sansui R70 maxpou Solid State 2 1st November 2009 10:21 PM
Copyright ©1999-2019 diyAudio
