Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 30th September 2015, 03:59 PM   #11
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
"Tweaking" the Super Pensil 12.2p - Advice?
The felt at the top is to reduce early reflections thru the cone. The smaller the cabinet the greater the benefit.
As a TL the Pensil uses quarter-wave resonance to make extra bass. The damping is to kill the unwanted higher frequency resonances that we don't want. Less damping means more bass but more ripple from the unwanted harmonics. More damping gives a smoother response with less bass.
Room, room placement, and taste play a role too so there is no fixed correct amount. The back is removable so that you can play.
In our build Chris ended up pulling out about a 1/3 of the recommended damping.
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 30th September 2015, 04:05 PM   #12
chrisb is offline chrisb  Canada
dave
To clarify, this was on our original build of A7 Pensil - I did something similar on an ongoing custom build of curved sided Pensils - net stuffing measured at 200grams.
Jeff (vinylkid) could probably answer questions regarding the SuperPs for 12.2Ps .
We’re just a bunch of monkeys on a big blue spinning ball - Don Caron
Old 30th September 2015, 06:46 PM   #13
withavee is offline withavee  New Zealand
Ok thanks guys. I'll add felt to the top and play with stuffing this weekend.
Old 2nd October 2015, 02:32 PM   #14
m3tr0g33k is offline m3tr0g33k  United Kingdom
I seem to have missed the development of the 12.2p since 2012.
Does anyone have completed frequency curves of the pensil and super pensil with the 12.2p?
What sort of room size does anyone have them in? I am blessed with less cleaning and a small living rom - about 5.5m by 3.3m, so my listening triangle would be a little less than that. About 3.5m between me and the drive units.
Just interested in a reasonably priced full-range project to go with a class-T with digital sources.
Thanks all!
Old 2nd October 2015, 05:38 PM   #15
Some thoughts for m3tr0g33k
I've heard the Alpair12.2P in only two enclosures - Jeff's SuperPensil, and a moderate sized standmounted design by Dave - Mar-KenT or some such name. I think this driver really wants a larger vented enclosure to deliver its full potential in the bottom several octaves.
The SuperPensil is not a tiny box - they can certainly have placement issues, and it sounds like your room would be rather on the smallish size to fully appreciate them.
Unless you've already reason to decide otherwise, either of the 10s might be a more practical choice - they work well in a wider range of enclosure sizes than the 12Ps, and certainly can deliver decent bass response in a much smaller box than the Supers.
The most recent "digital" (Class D) amp that I've quite liked is the TPA3116, but there are numerous other candidates to consider
Old 2nd October 2015, 09:00 PM   #16
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Originally Posted by m3tr0g33k View Post
What sort of room size does anyone have them in? I am blessed with less cleaning and a small living room - about 5.5m by 3.3m, so my listening triangle would be a little less than that. About 3.5m between me and the drive units.
I have my Pensils in a slightly larger room, with an added "L" bit. The speakers aren't terribly wide, but are quite deep. You might want to consider the A10p in a Pensil box as well.
No T amps here, just tubes. The 12p's will play with dynamics and authority with 18 watts/ch.
jeff
Old 5th October 2015, 10:22 PM   #17
Jeff - did you ever record the weight of fill used?
Old 5th October 2015, 10:41 PM   #18
vinylkid58's Avatar
The bag was around 560-580 grams IIRC. So each speaker got roughly a half of that.
jeff
Old 5th April 2019, 02:37 PM   #19
Niceonecyril is offline Niceonecyril  United Kingdom
I am keen to build to build an Alpair 12.2p loudspeaker myself. Like many others have I am considering the Pensil or SuperPensil. I note that the geometry of the speaker in the vertical/horizontal planes is the same. Only the speaker depth varies. Also, recommended stuffing density is the same and dependent on preferences.
I would like to ask the following to Scottmoose or anyone in the know please: can one consider all possible speaker depths between Pensil and SuperPensil reasonable? Would I be correct to assume that listening tests would reveal a continuum of experience such that the character of the speaker would change smoothly from the Pensil toward the SuperPensil as depth is increased? Perhaps mysterious factors (to me at least) may prevent this from being the case.
Thanks!
Old 5th February 2020, 03:14 PM   #20
Toby Jug is offline Toby Jug  United Kingdom
Is there a sweet spot in the Pensil range, I'm thinking about a 10 or 12 , but was interested in finding out if there is a combination that woks beyond expectations.?? A size that maybe Gells better than most ?
"Tweaking" the Super Pensil 12.2p - Advice?Hide this!Advertise here!
My Super Pensil 12.2p Build -With Pics! tlarwa Planet 10 hifi 12 12th January 2015 04:07 PM
Is A Super Pensil 12.2p Width of 11.25" Okay? tlarwa Planet 10 hifi 6 8th December 2014 01:39 AM
Alpair Pensil 12.2p Build craigtone Planet 10 hifi 15 30th January 2013 12:18 PM
Thicker baffle for Pensil 12.2P zman01 Planet 10 hifi 7 20th December 2012 07:24 PM
Alpair Pensil 12.2p Build craigtone Planet 10 hifi 0 28th October 2012 03:24 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
