Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Thread Tools
Old 2nd June 2021, 12:02 AM   #381
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Alpair 7P & Alpair 12PW combination.
a sealed a11ms with the 7p
A11ms in butterworth sealed has F9-6) at about 70 Hz. 70-20k is abit over 7 octaves.
3-4 octaves for either would put the XO between 600-900 Hz.
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 2nd June 2021, 12:23 AM   #382
lasercut is online now lasercut  Ireland
Listening to 11ms now with digital 1st order 900Hz low pass there is still a surprising amount of HF content audible, and naturally it would be the reverse for 7p.
Over-generalised, I could see a5 vs a7 as a matter of mid vs treble quality for this.
Old 2nd June 2021, 01:32 PM   #383
A bit earlier in thread you mentioned 11ms does not make a good midwoofer, is that because of bass extension or other factors?
Old 2nd June 2021, 03:20 PM   #384
frugal-phile(tm)
planet10's Avatar
The bass extention is relatively poor. Low Qt, small Vas. In an optimum miniOnken for instance A7ms goes a couple Hz lower than A11ms.
dave
  Reply to this post
Alpair 7P & Alpair 12PW combination.Hide this!Advertise here!
Thread Tools
Alpair 7P directivity measurements tomchr Full Range 28 16th December 2019 12:30 AM
Mark audio alpair 7p vs alpair 7.3 sarathssca Full Range 157 21st March 2016 02:24 PM
Is this material suitable for damping an alpair 7P /12PW cabinet? timpert Planet 10 hifi 5 23rd May 2015 04:28 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
