Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 16th June 2015, 05:12 PM   #21
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
ufonken build assembly suggestions
From your picture the bezel is not flush… that it usually the goal with the rebate. So there is probably room for more rebate.
If you don't want to domore rebate, orit still doesn't reach the holey brace, then you want to use something fairly stiff to bridge the difference, a sliver of wood, or even a piece or 2 of paper.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th June 2015, 02:39 AM   #22
chrisb is offline chrisb
The supplied gadget is thin and narrow enough to have virtually no effect on the depth of rebate required for bezel to be flush with baffle, which IIRC is no more than 3 mm
I'd consider a different head on the mounting hardware - if you're using machine screws and threaded inserts, try button head rather than cap screws.
Fate - something that people make up to try to explain how things worked out
Old 4th January 2016, 04:57 PM   #23
nickds1 is offline nickds1  England
nickds1's Avatar
Completed these now... I rather like the stainless steel hex-machine bolts with M4 brass inserts,
Love them - veneered in American Black Walnut and given a few coats of wax/oil... rebate and ports pre-painted in black, then veneered & cut through - finish was very clean.
Nicko
"The whole plan hinged upon the natural curiosity of potatoes" - S. Lem
Old 4th January 2016, 06:16 PM   #24
frugal-phile(tm)
planet10's Avatar
Excellent
dave
Old 11th April 2016, 07:59 PM   #25
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
Nice work Nicko!
How do they sound?
I collect projects - building them is another hobby altogether
Old 13th April 2016, 08:45 AM   #26
nickds1's Avatar
Very pleased with them - I don't often make speakers, but needed a decent desk-top/near-field pair for a small valve amp I'm building.
Surprisingly good range from such a small speaker - highly directional (of course), but can fill a room if needed.
Soundstage is good - extremely well defined (as you would expect) - they are best used at or just below head level between 1 and 2 metres away with the units approx 1.5 metres apart.
Currently using a small APPJ PA0901A amp - very nice sound.
Nicko
ufonken build assembly suggestionsHide this!Advertise here!
Troels' PMS (multilayer assembly) build thread WaveFlex Multi-Way 129 3rd September 2014 05:09 PM
New uFonken Build Started timske Full Range 19 25th January 2014 03:01 PM
First Build - Suggestions? K5Doom Multi-Way 11 2nd March 2011 07:21 PM
Fat ufonken build jpbturbo Full Range 7 9th November 2009 02:20 PM
Copyright ©1999-2019 diyAudio
