Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 21st October 2011, 08:45 AM   #21
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Mar-Ken with Alpair 7.3
Originally Posted by silverhairbp View Post
Though it might be a bit large for the WoofT design, the Peerless SLS 8" driver (830667) looks like a good match.
After settling on the little Peerless for the baby WoofT, the Peerless units are on the must check list. Reasonable prices, and they seem to get kudos from many. It doesn't hurt that the trimmed baskets have always appealed to me.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 21st October 2011, 10:41 PM   #22
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Dave, Have you looked at the Seas ER18. Very good from what i hear and has lots of travel to play with to push LF output.
Old 21st October 2011, 11:09 PM   #23
frugal-phile(tm)
planet10's Avatar
I will be looking at a wide range of drivers... looks like a 6 1/2" unit will be as large as i can go, althou in the larger ones i could maybe use 4.
dave
Old 21st October 2011, 11:37 PM   #24
buzzforb's Avatar
I may try a dual version. It is very well regarded by everyone who has used it and is very inexpensive.
Old 22nd October 2011, 05:24 PM   #25
zman01 is offline zman01  Bangladesh
Just out of an extensive session of FAST experimentation with Banglacx. He had this idea of using the Foobar digital XO plugin for our project, and wow did that work.
In short, FAST works very well in adding that low end authority to the superb Alp 7.3s. Sound stage becomes bigger, taller and playing bass heavy music at much louder levels no longer remains a threat to the FR unit. We were at it for >5 hours and now need a break . Will post details soon.
-Zia
p.s. The Mar-Ken 7.3s have left the building
Old 22nd October 2011, 05:27 PM   #26
frugal-phile(tm)
planet10's Avatar
Originally Posted by zman01 View Post
Just out of an extensive session of FAST experimentation... and wow did that work.
Old 22nd October 2011, 05:33 PM   #27
buzzforb's Avatar
I thought it would improve things significantly.
Old 22nd October 2011, 09:14 PM   #28
banglacx is offline banglacx
*sneak preview*
By itself, the Mar-ken-7.3s can sound anything from a club grade unit armed with a subwoofer producing PHAT bass to something that'd make you want to assault Dave with a cutlass / violin fiddle / whatever comes handy. These speakers are very, very room / placement dependent. For anyone wanting to use them in a nearfield mini-monitor configuration with a lot of space between them and the wall - you're in for big trouble. Place them close to a wall and put some distance between you and the units... well, this is the best configuration you can get with the Alpair 7.3s. Trust me on this - me and zman01 has tried several design implementations.
As for the F.A.S.T. - zman01 will post the listening impressions with configuration details... and of course, pics. I'll chip in with my comments after he does.
Old 23rd October 2011, 12:20 AM   #29
markaudio is offline markaudio  Hong Kong
markaudio's Avatar
Originally Posted by banglacx View Post
*sneak preview*
Hi Banglacx,
Have you tried other rooms?
When I listened to Dave's Mar'Ken at Tony's place, I was pleasantly surprised by their performance in a high ceiling but narrow(ish) room environment when other systems haven't coped quite so well.
It maybe you have some particular or unique characteristics specific to your room thats impacting on the system.
Cheers
Mark.
Old 23rd October 2011, 01:01 AM   #30
buzzforb's Avatar
I have listened to the 7's for a couple of weeks now in a 16' x 16' room that is open on one side. Pushed against the wall, the bass is pretty good if not respectable. Unfortunately, other facets suffer as a result. When pulled out into my room 3', about 7'-8' apart with me sitting 3' from the rear wall, the bass is pretty lacking. In this setup, however, the speakers sound phenomenal otherwise. I believe that yours and Zman's findings are in line with what i would expect and what i have found with this speaker in the MarKen enclosure. I believe the Pensil would help, but the best chance at bigger sound would come from one of Scottmoose' large enclosures. Any of these are setups i believe are really asking more from this size FR unit than it is IDEALLY suited to deliver. The MarKens and A7's deliver everything Dave and Mark said should be expected, and would probably be fine in a 10' x 10' room like Steven Z has, but we must not forget that this is a 4.5" driver and in a large room like mine, they are fighting an uphill battle. It is not a deficiency, but physics. Relieve it of its LF responsiblities at about 100-180Hz and listen to this angel sing. I had a chance to do this momentarily with a simple sub and could not have been more pleased. I will be working on FAST system as soon as I finish a couple of amps. If it performs as expected, this may be a stopiing point for me for quite some time. They are that good.
Mar-Ken with Alpair 7.3Hide this!Advertise here!
Alpair 6p vs alpair 6m vs alpair 7 timreeves Full Range 11 8th January 2013 04:37 PM
Mar-Ken 12 Octagon Douglas Ingram Planet 10 hifi 1 17th September 2011 10:47 PM
Excess Mar-Ken enclosures A6 & A7 bamboo ply planet10 Planet 10 hifi 18 16th September 2011 10:20 PM
Mar-Ken golder ratio 10.2 plan dainrobert Planet 10 hifi 3 29th March 2011 09:20 AM
Alpair 12 Classic Golden Ratio Mar-Ken12 planet10 Planet 10 hifi 6 1st March 2011 08:13 AM
Copyright ©1999-2019 diyAudio
