Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 2nd March 2020, 07:12 AM   #51
nautibuoy is offline nautibuoy  United Kingdom
nautibuoy's Avatar
I have seen it suggested that the 10in Lii Audio drivers (datasheet for the ones I have attached) would be well suited to an Onken project - a not so mini variant of the Planet 10 miniOnken designs;
I've played with this calculator;
HiFi Loudspeaker Design
and it all looks good with an overall calculated SPL of 93.6 (dB 1W/1mtr) (which my only concern because of the flea-power amps I currently use). The bottom end -3dB point is calculated to be at around 30Hz.
Thoughts?
Old 2nd March 2020, 06:18 PM   #52
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
planet10-hifi miniOnken Plan-Set Subscriptions
It looks like that is so.
400 litres, F6 & F10 both in the low 20s (F3 is meaningless to humans)
But it can be squeezed into a smaller box:
300 liters F6/F10 still in th elow 20s
250 liters, F6 drifting into the higher 20s
200 liters, F6 now in the upper 20s, a bit more midbass punch
150 liters F6 into the low 30s, F10 high 20s.
I’d look at the 200 litre box. Benefits in terms of material cost, getting the box not to move, and the midbass punch all appeal.
How is the SPL different than specified. Where are you loosing so much? This thing should wail with a watt or so.
Note that that calculater is for an Onken, not a miniOnken.
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 2nd March 2020, 06:51 PM   #53
nautibuoy's Avatar
Thanks Dave. A Watt or so is what I've got!
I'm mulling over what to do with these drive units at the moment, maybe some miniOnkens, maybe a bass reflex, maybe an OB...
Do you have any suitable plans secreted about your person? Large floorstanders are fine, though I've not really mapped the volumes you mention to physical box sizes.
Cheers
Ray
Old 2nd March 2020, 07:10 PM   #54
frugal-phile(tm)
planet10's Avatar
No miniOnkens have hit 200 litres yet, but that is just some grunt work. IIRC 135 litres is max (for a 15” bass driver).
dave
Old 2nd March 2020, 08:23 PM   #55
nautibuoy's Avatar
Originally Posted by planet10 View Post
No miniOnkens have hit 200 litres yet, but that is just some grunt work. IIRC 135 litres is max (for a 15 bass driver).
dave
OK, that would seem to narrow down my options then.
Old 2nd March 2020, 08:53 PM   #56
frugal-phile(tm)
planet10's Avatar
A custom design is only a doation away.
email me if you want to talk further.
dave
Old 3rd March 2020, 02:33 AM   #57
nautibuoy's Avatar
dave
Thanks Dave, it's good to know that the option is available and I may well come back and take you up on it. This is not a pressing issue as I need to complete some other projects before I entertain a speaker builld so I have the luxury of being able to procrastinate for a while.
Having done some quick calculations I'm begining to appreciate the physical size that those cabinet volumes translate into.
Old 3rd March 2020, 03:28 AM   #58
frugal-phile(tm)
planet10's Avatar
BIG. 7-something ft3. Net.
dave
Old 24th March 2020, 11:52 PM   #59
dmar836 is offline dmar836  United States
Dave,
Didn't I see a post attachment somewhere of a MiniOnken for the Dayton PS220-8? Was hoping someone had built it with listening impressions.
Couldn't find it again but was hoping it would be floor standing and trapezoidal. The Singularity and Pensil are a bit simple. What can I say? I always take the hard way.
Dave
Old 25th March 2020, 01:53 AM   #60
Found it on the ”Dayton 8" FR PS220 Discussion” thread and it is trapezoidal. Has anyone built and tested this?
Dave
planet10-hifi miniOnken Plan-Set SubscriptionsHide this!Advertise here!
planet10-hifi, clearance of a few R&D pairs of EnABLed drivers planet10 Swap Meet 11 27th January 2012 02:42 AM
missing instant emails from thread subscriptions leadcoma Forum Problems 0 20th December 2010 02:27 PM
EnABled EL70 from Dave at planet10-hifi khundude Full Range 8 11th September 2009 10:17 PM
Welcome to Planet10-HiFi planet10 Planet 10 hifi 0 21st August 2009 04:39 PM
Set up ultimate audio from PC to HiFI and TV BeachnBoi Digital Line Level 1 26th October 2008 01:33 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
