Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 16th July 2018, 05:45 PM   #551
Sarchi is offline Sarchi  Canada
Sarchi's Avatar
Originally Posted by planet10 View Post
No none of those work with FE127e. email me and i can send you the Fonken planset.
dave
I did get those from you a while back. Thanks Dave.
Old 25th September 2018, 12:30 PM   #552
jmlynch55 is offline jmlynch55  United Kingdom
Default FH Lite
Hi to the forum
Main reason for posting : After reading all the pages I thought it would be good to encourage the continuation of this brilliant topic.
I am currently building some FH Lites. Almost completed.
What interests me the most is how much stuffing I should use. Obviously I can experiment with this. But, other people's thoughts would be interesting also.
I have mainly Tube amplification (vintage Fisher) and Vinyl is my thing.
The reason I ended up here is because I recently purchased a Philips AG 9016 amp which struggles to output 4 Watts. If I wore the speakers as if they were headphones I could hear them OK. Then I came across the principle of Folded Horn speakers and thought I'd give it a try.
Be nice to hear if anybody out there in the UK doing the same stuff.
This is an excellent forum. Very pleased I came across it
Jim
Old 29th September 2018, 12:49 AM   #553
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Frugel-Horn Mk3 flat-paks
The damping is fairly well specified in the plans. The damping in the point is fixed but that below the driver on the front is variable based on driver/room/room position, and taste. All things you will have to play with once you are listening to them. Don’t be tempted to fiddle too much until the drivers are broken in.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd October 2018, 10:40 PM   #554
Many thanks for your information Dave.
I'll get back to the forum and give some results as soon as I can.
Old 10th October 2018, 04:26 PM   #555
Just fired up my Frugel-Horn Lites. Only packed the V sections with stuffing so far.
I didn't expect much as I know these speakers need to be run in and the correct amount of stuffing should be experimented with.
They sound very sweet straight away. My usual speakers are KEF LS50s.
My listening room is quite small and I've always had trouble with bass boom and positioning of speakers has always been critical.
Amplification, if anybody is interested, is The Fisher X-202-B. Source is TD 124, SME 3012 S1, Denon 103R. Gonna try Ortofon SPU tomorrow.
Will post again when speakers are run in. 100 hrs?
Jim
Old 11th October 2018, 05:05 AM   #556
chrisb is offline chrisb
hella nice front end Jim - which drivers?
Technology honors no Hippocratic oath
Old 11th October 2018, 04:15 PM   #557
Hi Chris
The drivers are Mark Audio Alpair 5 gen 2. They are dinky little speakers but are sounding really nice already. I'll let you know how they are when I've run them in if you like.
My listening room is quite small. Not sure how they would fare in a larger room.
I have some KEF LS50s which are great speakers. But, certain recordings the bass can be boomy. I've got 8 bass traps (4 of which I made myself). Really need them in my room. They definitely help. The Alpairs don't seem to suffer from any boom thus far. But, as you would expect the bass is quiet. But, well defined.
Thanks for taking an interest.
Regards Jim
Old 11th October 2018, 11:40 PM   #558
Haven’t had a chance to hear the little KEFs, but am quite familiar with almost all the Alpairs, and the little 5.2s definitely punch way above their weight class.
Old 13th June 2019, 02:39 PM   #559
Siddhant Merh is offline Siddhant Merh  India
@planet10
I recently brought my first stereo: frugal horns with alpair 7p and a Hiraga Le Monstre 8 watt amp both made by renowned DIYers in India. Yet to make the preamp: Pass b1. I was using volumio OS from my Boss DAC to control the volume digitally (it's always a loss without jumpers). All of a sudden the OS restarted and the initial starting of the OS makes a 2 second sound just like the starting sound of Windows XP. The volume goes by default to 100% and it clipped the drivers. Anything that can be done? I feel so doomed. Volumio OS is full of glitches..
Old 14th June 2019, 05:37 PM   #560
notnickparkin is offline notnickparkin
Hey Planet 10, do you have any MK3 frugal horns available????? im located in the United States.
Frugel-Horn Mk3 flat-paksHide this!Advertise here!
Frugel-Horn Mk3 Builds & Build Questions planet10 Full Range 1401 19th January 2020 02:14 AM
Frugel-Horn Mk3 planet10 Full Range 1786 21st December 2019 07:47 PM
uFonken flat-paks planet10 Planet 10 hifi 20 23rd January 2015 08:35 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
