Planars & Exotics ESL's, planars, and alternative technologies
Full range planar speaker using neo magnets
Old 29th August 2019, 07:13 PM   #411
L.rivera92172 is offline L.rivera92172  United States
Would love to make one can you make a tutorial on making one how do you calculate ohm with the aluminum tape and would the frequency it plays depends on size please help a brother out thank you in advance
Old 30th August 2019, 09:02 AM   #412
JAMESBOS is offline JAMESBOS  England
for a size 24" x 16" one you have to use 3 mm wide tape, and for my next build 38" x 16" I am using 5 mm tape which is easier to deal with. Both put on vertically wnich saves magnets. I use 40 x 20 x 10 mm ferrites. Which I buy from ENES MAGNETS in Poland which are the cheapest for me.
HENRY
Old 8th November 2019, 01:20 AM   #413
marklawrence is offline marklawrence  United States
Originally Posted by JAMESBOS View Post
the main problem is the diaphragm material, stopped using thin mylar, and thick poly using a completely different material now, I have seen the light after 10 years of trials and tribulations.
What material are you now using for the diaphragms?
Old 8th November 2019, 09:13 AM   #414
Default full range planars
several different ones, christmas wrapping paper, photos printed on photo material plain un-printed paper. I can put different pictures on. A lot easier to use than mylar, you don't have to stretch just put in position you can glue them on or just hold them on with screws or picture frames, easy peasy!
HENRY
Old 8th November 2019, 09:25 AM   #415
Stopped using neos as well too hard to fill membrane and too expensive use 40 x 20 x 10 ferrite ones now from enes magnets poland. Also use less ferrite ones as well using different layout as well. Using less magnets is just as sensitive as using more magnets you live and learn, have built and rebuilt over 500 full range planars over the last 15 years and I am still learning.
HENRY
Old 8th November 2019, 05:20 PM   #416
I'd like to see a picture of your layout, with a ruler laying over the magnets so I can see the spacing.
Old 11th November 2019, 02:03 PM   #417
jzagaja is offline jzagaja  Poland
Henry,
Sorry if someone asked before - your experience with biaxially oriented PP foil used for baking?
Visit us at http://www.diysoundgroup.com
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 11th November 2019, 02:15 PM   #418
i USE 3 MM AND 5 MM ALUMINIUM TAPE 50 meters per roll, which I get from the masking shop.
HENRY
Full range planar speaker using neo magnetsHide this!Advertise here!
my 14 inch full range speaker! chinese Full Range 235 21st September 2010 02:30 PM
Where to find magnets???For Diy Planar floydturbo Planars & Exotics 8 27th July 2010 11:28 PM
16 Ohm Full-Range Speaker thelordash Chip Amps 13 23rd January 2009 06:13 PM
full range speaker for HT Jazzz Full Range 13 8th September 2006 09:27 PM
beginner full range speaker tacomaboy Full Range 5 12th January 2004 08:38 PM
Copyright ©1999-2019 diyAudio
