Planars & Exotics ESL's, planars, and alternative technologies
A DIY Ribbon Speaker of a different Kind
Old 18th August 2018, 10:08 PM   #1251
sergiu2009 is offline sergiu2009  Romania
sergiu2009's Avatar
Looking forward too solhaga. You have a very interesting way of assemblying the motor and a very powerfull motor there. How much did you simulate it has in T?
I use a more invasive and messy way of assembly where you have to be very carefull with your fingers...
As a hint, you can observe now that the bars bends only (if they are strong enough) when you join the whole magnet motor. If the gap remains constant for a week then you are good to go, if not.... add reinforcements, like thick U shaped of harder steell and bolt them to each side of the magnets.
It will become a bit bulky (at least 5kg in plus) but will hold.
Cant wait to hear you impressions and see your results.
Cheers
Sergiu
Old 18th August 2018, 11:07 PM   #1252
solhaga is offline solhaga  Sweden
1.8 T. Look at the first motor in post #1238
The gap width is stable, but I've put an extra 3 mm spacer between the mid membrane and the tweeter membrane just to be sure:
Old 19th August 2018, 02:11 PM   #1253
sergiu2009's Avatar
I cannot see your pic. Can you upload it again?
Old 21st August 2018, 12:02 PM   #1254
Yroger is offline Yroger  France
Bonjour,
Après toute ces années de questionnement et de recherchepersonnel j'ai décidé de vendre les équipages mobiles (circuit et membranes) dumodèle Janus 50. Il s'agit des versions originales fabriquées par MrDeminière et jamais montées car faute de moyen pour me procurer tout lereste des éléments constitutif de ce transducteur sonore.
Sur son site elles sont vendues à 300E; je suis ouvert auxpropositions si toute fois cela intéresse quelqu’un. :wink:
Dans l'attente, cordialement
Hello,
After all these years of questioning and personal research I decided to sell the mobile crews (circuit and membranes) of the Janus 50 model. These are the original versions manufactured by Mr Deminière and never mounted because of lack of means to get all the rest of the constituent elements of this sound transducer.
On its site they are sold at 300 Euros; I am open to proposals if anyone is interested. : Wink:
In the meantime, cordially
Old 20th September 2018, 07:58 PM   #1255
ndhennin is offline ndhennin
I am starting to work on the construction : grinding the metal at the moment.
A question poped up in my mind concerning the connexion between the coils ans the wires coming from the amp : I am going to make the coil with aluminium wire : 0,175 mm for the diameter. Is this section big enough to link the coil to the wires coming from the amp ? sounds thin no ?
Old 20th September 2018, 09:29 PM   #1256
sergiu2009's Avatar
nope
Old 20th September 2018, 09:30 PM   #1257
sergiu2009's Avatar
use some flux eventually ...
Old 24th September 2018, 03:40 PM   #1258
Hello,
Difficult to do better than the original circuit which is only 2 / 10th of thickness in total only. Mr Deminière had his circuits manufactured by a professional. Various variants have been tested over the years for an impedance around 7 ohm.
Old 25th September 2018, 01:01 AM   #1259
WrineX is offline WrineX  Netherlands
WrineX's Avatar
sick amount of Tesla now comes the fidling job... 3mm sounds big but with paper over a big distance it is still is pretty small
looking forward though
Old 26th September 2018, 05:36 PM   #1260
I've made two types of membranes: one 3D printed and one laminated carbon fibre.
3D printed:
Mounted:
Sounded like this .
I had no suspension on this one, so it wasn't in the middle of the gap, hence the scratching sound.
It measured like this (1W @ 1m):
Too high distortion for my liking, so I decided to laminate some carbon fibre, 8 gr/m2.
And at the same time make a smaller membrane, this time with suspension:
They sounded like this (200 Hz cut off).
I measured it, but thought that the distortion still was too high.
So I put some dampening inside.
It then measured like this (1 W, 0,25 m):
Still too much distortion and not enough SPL in the lows.
In the highs I was thinking of designing a tweeter anyway.
So I needed to make the suspension better,
experiment with other membrane materials,
read all pages of this thread,
and ..
Then I realized that it will take some time and effort to get this right and making them better than SLAM!
I wanna do other stuff, like listening to my fantastic SLAM! speakers and playing with my Prusa 3D printer, now with five color/material printing.
By the way, SLAM! sounds like this in a my setup.
A DIY Ribbon Speaker of a different KindHide this!Advertise here!
Ribbon Bookshelf Speaker LineArray Multi-Way 2 6th June 2008 12:38 PM
What kind of laptop to analyze speaker ostie01 Multi-Way 2 27th December 2005 08:18 PM
New Ribbon Speaker Technology - Approach the perfect speaker? cocolino Planars & Exotics 49 16th January 2005 11:12 PM
What kind of speaker design is this? Keith TDI Multi-Way 8 25th March 2002 04:56 AM
Copyright ©1999-2019 diyAudio
