Planars & Exotics ESL's, planars, and alternative technologies
Ribbon mic question
Ribbon mic question
Thread Tools
Old 21st July 2021, 07:37 PM   #1
hellokitty123 is offline hellokitty123  United States
Default Ribbon mic question
Hi, I recently came upon this thread
Ribbon mic (DIY) - Bigger gap to shorten front to back path. | GroupDIY
where PRR mentioned that the magnetic strength of a ribbon mic can affect whether it is resistance driven or mass driven. But it was my understanding that magnetic strength only affects the sensitivity.
If X amps are being run through Y magnetic field, the effect on the ribbon should be the same regardless of X and Y as long as X is sufficient.
So why did PRR say that the magnetic field can negate the effect of mass on a ribbon?
  Reply to this post
Ribbon mic questionHide this!Advertise here!
Thread Tools
How to make mic input transformer 150:50KCT for mic tube preamp??? delipasha Instruments and Amps 9 3rd February 2012 05:54 AM
Beyer MM-1 RTA Mic Best Budget RTA Mic Zero Cool Swap Meet 3 5th May 2009 05:32 AM
4-pin mic converted to a 2-pin electret mic? silentblackhat Solid State 1 10th January 2008 06:50 PM
'Tube' preamp bad for measurement mic? also Apex mic question morbo Multi-Way 10 23rd March 2005 10:19 AM
What mic preamp for Behringer testing mic The Paulinator Multi-Way 1 6th April 2003 07:02 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
