Planars & Exotics ESL's, planars, and alternative technologies
SALS?A! - a very long story
Thread Tools
Old 27th September 2021, 08:37 PM   #61
solhaga is offline solhaga  Sweden
solhaga's Avatar
Originally Posted by WrineX View Post
very nice i made this kind of thing a while ago. im not sure what made me dispose of it (might be my not so perfect folds) looking forward to you result ! looks great so far !
Thank you, Wrinex.
I hope that I in a day or two will have some measurements made.
Old 27th September 2021, 08:40 PM   #62
solhaga's Avatar
damned i want a plasma cutter to looking for an affordable one i can strap to the cnc may i ask what one you used ? if it is a hypertherm.... i must save some more i gues haha
I'm using a Hypertherm 45XP.
As I value my time a lot, I couldn't afford anything less.
Old 28th September 2021, 08:15 AM   #63
solhaga's Avatar
First membrane mounted in a speaker:
There might be need of an extra support at the middle of the membrane.
It'll be 11 mm in height between active membranes.
Old 28th September 2021, 12:48 PM   #64
WrineX is offline WrineX  Netherlands
WrineX's Avatar
damned a hypertherm haha i was afraid you would own one well if it is your work for instance !! i understand
maybe i should see if i can find a used one. i mean 1500 is allot of money
By the way i like the more simple design you build now, with the 3d printed bracket holding the steel in place. they also seem to work to not interfere (diffraction and such)
Old 28th September 2021, 03:57 PM   #65
solhaga's Avatar
I think I paid almost double that amount, with some extra consumables though.
Yes, when I made SLAM!, 3D printing was new for me.
I actually bought the printer after I started that project.
And I had ordered the pole pieces from a shop, they were €1.50 each.
Now I can make them for "free" with my own plasma cutter.
Old 29th September 2021, 04:07 PM   #66
solhaga's Avatar
Some first measurements then at approximately 1 W.
Only two membranes and no back pole pieces.
SALS?A! - a very long story-mid-hp-500-hz-jpg
SALS?A! - a very long story-tweeter-hp-1000-hz-jpg
SALS?A! - a very long story-tweeter-hp-1000-hz-mid-hp-250-hz-jpg
SALS?A! - a very long story-tweeter-hp-1000-hz-mid-hp-500-hz-jpg
SALS?A! - a very long story-tweeter-hp-1000-hz-mid-hp-500-hz-1-jpg
So the SPL at 1W 1 meter is a little bit low and the distortion is a little bit high.
But I reckon that the back pole pieces will add 3 to 6 dB and they will also lower the distortion levels.
Doubling the amount of membranes twice will also add at least 6 dB.
So I guess it'll be above 95 dB in sensitivity at 1 meter for the full SALS?A!
Frequency response slopes down above 15 kHz and are more or less the same for both mid and tweeter.
I don't know how much the narrower back pole piece for the tweeter section will help.
But the tweeter section is not only about high frequency response, it will also have a muck better dispersion being only ten millimeters wide.
File Type: jpg Tweeter HP at 1000 Hz Mid HP at 250 Hz.jpg (343.9 KB, 136 views)
File Type: jpg Tweeter HP at 1000 Hz Mid HP at 500 Hz.jpg (332.8 KB, 132 views)
File Type: jpg Tweeter HP at 1000 Hz Mid HP at 500 Hz At 1 m.jpg (329.7 KB, 133 views)
Old 29th September 2021, 09:33 PM   #67
solhaga's Avatar
I'm thinking of adding supports for the tweeter part of the membrane.
If I replace an ordinary 3 mm back pole piece with a 1 mm tweeter support:
together with a 2 mm back pole piece:
I'll get four 65 mm sub-sections and the HF response should get better.
The rest of the back pole pieces are still 3 mm thick.
Old 30th September 2021, 01:47 PM   #68
solhaga's Avatar
I did four supports, so there's five sub sections in a membrane
The support also helps keeping the mid in the middle of the gap deepth.
Now I got to make 66 3 mm back pole pieces and then I can redo the measurements above.
Old 2nd October 2021, 04:47 PM   #69
solhaga's Avatar
Measurements on the same two membranes but now with the back pole pieces.
No HP filtering and still with 1 W input power:
So SPL went up overall by 6 dB!
One can see that the tweeter needs a HP filter at 2 kHz or so but the mid HP filter can be lower than the current 500 Hz.
Lets see how it all plays later in the complete system.
With some FIR filtering this is going to be good.
So now I have to produce the rest; this was only an eight.
Old 4th October 2021, 01:03 PM   #70
solhaga's Avatar
Horizontal dispersion; -45° to 45°. The order is given by the colors given at vertical cursor at 10.29kHz.
Measured at 1 W and 60 cm distance.
It is hard to read because of the reflections from the room and furniture, but I think it looks as expected.
SALS?A! - a very long storyHide this!Advertise here!
Thread Tools
First Open Baffle Project - Augies, Sals, & Alpair 12p Dneu2011 Full Range 9 5th November 2019 06:09 PM
phono preamp grounding/hum long story 240zracer Analogue Source 8 24th May 2011 10:19 AM
A long ...listening story east electronics Solid State 2 18th September 2009 04:51 PM
Very very very small sub robomatique Subwoofers 13 25th January 2006 10:25 AM
End of a long and beautiful aircraft story Netlist The Lounge 7 26th October 2003 03:03 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
