Planars & Exotics ESL's, planars, and alternative technologies
Monsoon PM-9 Transformer
Thread Tools
Old 23rd November 2020, 06:04 AM   #11
Sangram is offline Sangram  India
Sangram's Avatar
Safer to use 13V. The 25V cap will be on the edge for 15VAC.
Old 23rd November 2020, 07:10 AM   #12
yorab is offline yorab  Singapore
Ok, great. Where is a good place to start searching for one? Are there new parts for sale on this site?
Old 23rd November 2020, 07:20 AM   #13
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Easiest might be to get a 220 to 110v transformer/autoformer.
You will not likely find a Monsoon part.
PM14 is not likely the same as PM9.
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 23rd November 2020, 11:42 AM   #14
thoglette is offline thoglette  Australia
thoglette's Avatar
What Planet10 said. Given the low power level it should be not to expensive. And unless .sg has radically changed in the last decade, there'll be plenty of places with them (Mustafa's comes to mind)
Old 23rd November 2020, 11:44 PM   #15
I'm hoping to not have another external component, hence the desire to change out the internal PT. However, I'm not sure if it's possible with currently available parts and with this specific circuit. It doesn't bother me to replace parts with non-OEM--again, if possible. I'm just not sure of all the ramification of swapping the PT.
Would something like this work?
https://www.newark.com/block/st-100-...0va/dp/55X2492
Old 24th November 2020, 12:02 AM   #16
oh, and thoglette, Mustafa's is a good place but not too far away is Sim Lim Tower and Sim Lim Square. They are the ultimate DIYer's paradise for electronics. Shops packed wall to wall, floor to ceiling with goodies
Old 26th November 2020, 01:17 PM   #17
thoglette's Avatar
Probably: it's 100VA which is the magic number, according to the label on the back of my PM-9
I can't honestly remember what the secondary voltage was but if you feed a a dozen volts AV into the primary & measure the secondary, then you'll be able to confirm what the correct voltage should be.
Old 29th November 2020, 04:36 AM   #18
I found an old wall-wart style voltage converter that I used to feed 120V into the sub's internal power transformer. Measured 12V across the secondary winding. I guess it's a 10:1 ratio for anybody who may need this info in the future.
I also measured the mains supply voltage and it was 240V, although Singapore is (I believe) listed as a 230V grid. I'd think that I should be able to find a relatively cheap 240V-to-12V power transformer rated for 50Hz. But then again, I haven't really started searching, apart from the link that I provided in the earlier post. I hope it doesn't turn into a needle-in-the-haystack search, lol.
Anybody with experience want to opine whether transformers rated at 50Hz and 220V, 230V and 240V at the primary would all work in this particular case?
Old 29th November 2020, 05:16 AM   #19
thoglette's Avatar
Generally not a problem.
Old 3rd December 2020, 01:32 AM   #20
I finally had some time to look around the local shops for a power transformer. Plenty to be had in the USD20-25 range.
However, the 100VA PTs that I came across are quite a bit larger than the original. This leads me to believe that:
1) the original Monsoon PT is a high-density special PT and therefore can pack 100VA capacity in a much smaller and lighter form (I highly doubt this based on the price point of the system)
or
2) the Monsoon PT is not 100VA, even though the subwoofer nameplate says 100W (see earlier picture)
I assume that if I undersize the replacement PT, then it could easily overheat or worse. Is there some way that I could determine the VA rating of the original PT so that I can confidently fit a properly spec'd replacement? Also, the original PT has a thermal fuse while most of the PTs that I saw at the shops did not have one. How critical would this be?
Monsoon PM-9 TransformerHide this!Advertise here!
Thread Tools
I fixed buzz in Sonigistix Monsoon planar magnetic drivers Andersonix Planars & Exotics 36 13th August 2020 04:58 AM
Monsoon planar drivers - has anyone used 'em? Spasticteapot Planars & Exotics 16 21st May 2012 02:22 PM
FA: Monsoon panel speakers fireman Swap Meet 0 4th September 2006 01:37 PM
impedance of monsoon planar 9 panels knifeinthesink Planars & Exotics 0 6th August 2006 11:59 PM
Monsoon car audio question dinamohumm Car Audio 2 15th January 2004 05:56 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
