Planars & Exotics ESL's, planars, and alternative technologies
New planar drivers at Parts Express
Thread Tools
Old 12th June 2021, 11:46 PM   #161
studiotech is offline studiotech  United States
studiotech's Avatar
Originally Posted by Remlab View Post
Thanks for providing a link. I skimmed all the pages for measurements, but somehow missed those
They look good, especially considering that you're using a very expanded vertical scale. Everything seems to go south below 600hz though
If I get a lot of variation in my pair of slims, Ill probably be sending them back. Sadly, my pair of BG Neo 10's had variations that were just too hard to live with(I may have damaged one). My BG neo 3's are fine though. If need be, I can take these up to 800hz with an 8th. I could live with that if it means better consistency
I damaged a few of my first set with too many rounds of solder/desolder. Units developed quiet wide variations btw themselves after originally being almost identical. I'm an expert level solder jockey too, so I was surprised, but when I called BG and talked with Chris Brunhaver, he explained how easy it was to deform the diaphragm material with too much heat. On the second set, I only ever used crimp on terminals to attach the speaker wires and the units have remained very consistent freq response over about 5 years now.
Word to wise. Using any of the planar drivers, DO NOT SOLDER.
Chris is now with PS Audio and working on revisions of their forthcoming (any century now) speaker line. Current versions are using a modified version of the Neo10/Neo3 coaxial design like in the BG Z62 center channel.
Greg
Old 13th June 2021, 12:12 AM   #162
Remlab is offline Remlab  United States
I've been following Chris's work with PS Audio for, like you said, a century now.
It's not what you don't know that causes trouble. It's what you do know that just ain't so..Mark Twain
Old 22nd June 2021, 06:06 AM   #163
noah katz is offline noah katz  United States
So has anyone listened to t6he Slims yet?
Noah
Old 30th August 2021, 05:51 AM   #164
architect is offline architect  Netherlands
I am curious too
Old 30th August 2021, 06:46 AM   #165
ErikdeBest is offline ErikdeBest  Switzerland
Yes!
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 30th August 2021, 03:21 PM   #166
Have not listened, but tested two samples. big hd peak at 1.5khz, so using it as a mid was out of the question. As a tweeter crossed at or above 2k with a relatively steep slope would probably work well though, especially for the price. I was only interested in it's application as a mid, and who knows, it may still sound great in that configuration, but the 1.5khz hd made it a nonstarter for me
Old 30th August 2021, 08:07 PM   #167
that's a shame - I too am interested in an application between around 800hz and 2-3khz instead of a Scanspeak 10F.
Old 2nd September 2021, 02:28 PM   #168
adason is offline adason  United States
adason's Avatar
Originally Posted by studiotech View Post
Distortion plots. 2nd order is RED and 3rd order is ORG
The original BG NEO8-PDRs kill it as long as you stay above 600-700Hz. Both samples were almost identical. Midrange performance from a simple harmonic distortion perspective is fantastic.
Most disappointed in the Radian, but it's still totally acceptable if you consider most of it's range is still below -40dB down or under 1%. Even some of the other drivers that look like they have a bad spike in the upper midrange are still at least -40dB, so overall pretty usable.
The Slim 8 is the worse of the bunch, as expected, with the highest levels below 1KHz. But used as a line array of tweeters, they sure are a steal.
Greg
nice measurements studiotech
I was specially interested in slim8 from grs, since I used it
here are some data I got, post #99:
viral projects, sort of
originally I wanted to use slim8 from 900Hz to 10kHz, then foster planar on top
however, distortion of slim8 was higher than I expected, not that it would sound bad or anything.
so I started raising the crossover frequency, to 1kHz, then to 1.2kHz, and it got better
Old 8th September 2021, 01:18 AM   #169
studiotech's Avatar
Latest and hopefully final version of PS Audio Fr-30 released. Still a 10" Neo-10 style driver for mids.
First Pictures of the new PS Audio FR30 Loudspeaker - Speakers, Soundbars and Subwoofers - StereoNET International
Old 9th September 2021, 12:50 PM   #170
mortron is offline mortron  Canada
They look beautiful. First glimpse reminds me of the Devialet Bluetooth speaker... you think function couldn't keep up with the form. Aesthetically you're not sure what to expect from them, but can only assume they'll deliver some great sounds.
I liked the comment "with as little as 100watts" like everyone has power on tap or something. Then again, having more power has always been a good thing IME.
New planar drivers at Parts ExpressHide this!Advertise here!
Thread Tools
60 pcs Parts Express 269-570 NSB drivers circa 2005 woofertester Swap Meet 4 13th June 2020 07:54 PM
CSS drivers now offered at Parts Express DiscoJones CSS 2 7th August 2018 10:53 PM
Parts Express drivers to build a L100 clone Sprags Multi-Way 5 9th March 2015 07:46 AM
New Tangband Sub Drivers at Parts Express form109 Subwoofers 1 6th February 2012 05:18 PM
New Audiopulse / TC Sounds subwoofer drivers at Parts Express. BHTX Subwoofers 3 29th March 2008 10:07 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
