Planars & Exotics ESL's, planars, and alternative technologies
New planar drivers at Parts Express
Thread Tools
Old 20th February 2021, 10:51 PM   #141
OllBoll is offline OllBoll  Sweden
Originally Posted by WrineX View Post
thanks for the effort ! they look rahter consistent. i do think your mic or preamp has trouble with the volume though at least i hope so, since a consistent 1.5 or more % 2e order distortion over the complete bandwidth is not ok if you ask me
That is a possibility, especially since I have already ruined one of the inputs on the preamp so it is possible the other one works but performs poorly. I guess in future measurements I'll probably use my USB mic to avoid any such issues.
And when I think about it I've done measurements before in post New planar drivers at Parts Express with driver #1 and in that measurement I got ~ 0.5% 2nd distortion @ 1W.
Old 21st February 2021, 01:07 AM   #142
bentoronto is offline bentoronto  Canada
Having trouble making sense of the curves. Great stuff but can you explain what we are looking at.
I'm a pretty strong advocate of dipoles (or, I guess, multipoles). It would be meaning to me if the panels were mounted on large flat baffles so that I could see what the front radiation was like and then what the back is like. Otherwise, the front and back get mixed together. Granted, that's just like in real life, but more useful to my understanding to see the front and back independently.
B.
HiFi aspirations since 1957. "When the toilet paper of Experience is depleted, the backside of Reason goes unwiped"
Old 5th March 2021, 11:00 PM   #143
B.
Sorry for the late answer but better late than never:
The first one Frequency Consistency. As shown in the third image of the measuring setup I've placed a measurement microphone fairly close and then placed the planar in a vice in while pushing it against the rivets. This is such that I can swap the drivers and still get a pretty consistent measurement.
And consistency is the key. While I have measured the frequency response of the driver I don't really care about the actual response. If I did I would measure from a greater distance which would yield a more flat curve. What I care about is how different is every driver to each other driver.
All drivers are different, the best drivers are not good just because of fancy motors and such. They are good because the drivers have excellent consistency. With such you can take any driver and swap it with any other and you wouldn't have to change the crossover, it would perform pretty much the same.
For Bohlener Graebener original drivers that isn't true, and especially not true as of late. In fact the driver to driver consistency got so bad that at least some suppliers stopped stocking them.
That is what made me suspicious of the GRS drivers since they are suspiciously cheap clones of the BG planars. I expected consistency to be pretty bad, although for the price I was willing to accept a few garbage drivers and some better and some worse.
In the end I didn't really have any bad drivers. With the exception of below 700 hz the driver to driver variation is really good. At worst around 3 dB and mostly better.
That is great for me since I'm building a shaded array and it would be a pain to have to tailor the shading for each specific driver. As it is now I need 14 drivers and have 17 so I'll just put away the outliers as spare drivers and then average the response of the rest. Then I'll use that average driver as basis to calculate my shading.
Impedance Consistency is masuring the resistance of the driver. It says 8 ohms but it's not really 8 ohms. It is rather 6.5 ohms with a bump around the resonsance frequency. Here too we want all drivers to be as closely clumped as possible for easy use.
Old 7th March 2021, 03:25 AM   #144
horu5 is offline horu5  Germany
Default crossover
Originally Posted by studiotech View Post
I sure do! Thx.
How did you implement the crossing over of frequencies?
Use EQApo and RePhase -> pure clean mathematically correct control over Time and Frequency domain. Many TAPs steep steep filtering > 80db>Okt to prevent "coiling". No MiniDSP etc. unless FIR and no analog input into these: DA/AD/DA conversion will destroy the sound. The worst is "Phase Errors" due to "conventional" crossovers. These will destroy all imaging and add coloration due to uncontrolled summing up of frequencies and time shifts.
Best dedicated class A amplifiers for each driver mid/ treble, maybe the JLH 1969. Bass best class A/B. If you change the electric side it will be a complete different thing! ..my experience!
Old 8th March 2021, 04:27 PM   #145
capslock is offline capslock  Europe
Originally Posted by OllBoll View Post
I can verify that the same trick works on a normal Neo8, it does extend the high end a bit. I have gotten more smooth results with a less wide baffle though, on the order of 10 cm or less. This 30 cm baffle is a bit extreme but I wanted to specifically test the extreme case in that measurement.
With a smaller baffle that covers ~ 10 cm and that covers the outermost two holes we get the following on a Sounderlink Neo8 which is basically the GRS wide 8" but more expensive, more distortion and less consistency*. (*My guess based on the consistency of the slims, probably similar for the other planar drivers from GRS)
Note that even with those tricks the top end at 10 khz and above is still worse than the slim. Not by a huge amount sure but a bit worse.
There is also the fact that the wide 8" is well, more wide Probably not an issue for most but I'm building a dipole and in this case it is very advantageous to have the slim design. A dipole with a hard baffle will create a null on the other side, as can be seen in the measurements. The bigger the baffle relative to the radiating area the bigger the null. It's not a huge null but it is there from 4-7 khz and no amount of wool I have thrown at it has eliminated it.
The slim driver has a lot less baffle but the same radiating area, so this null is pushed higher in frequency which is a good thing. I believe with some tweaking of the wool baffle (mostly reducing width or curving it to create a mini-waveguide) and with more drivers I can eliminate the null with the slim driver.
What do you mean by "create a null on the other side" and is it in the masurements you attached to this post?
If your talking about the rear side, that should be the same as the front. Or are you talking about edge diffraction off the edge of the baffle? But that is hardly the other side?
Old 8th March 2021, 06:25 PM   #146
With a hard circular baffle that is wide relative to the driver it creates a sharp null in the 0 degree direction to the front and the rear:
Here are [0, 15, 30, 45] measurements of a 6.5" midrange (AE TD6M) on a 50 cm wide circular wool baffle (Red), 50 cm wide circular wood baffle (Blue) and naked with no baffle at all (Green).
With a solid baffle there is a sharp dip at 1200 hz -ish @ 0 degrees. That null with a solid baffle is basically the reason why so many dipole builders go for no baffles or very small baffles. Usually 4-way since then you can't have both the low frequency extension of a small baffle and the high frequency smoothness of no baffle.
The wool baffle smushes this around and just reduces the 0 degree by 1 dB or so in the 700 - 1200 hz range. The tradeoff is that we get almost the same low frequency as with a solid baffle which is huge and in my opinion well worth it considering how minor the impact is in the 700 - 1200 hz range.
Addition: This is the extreme case since the rear of the cone driver stops impacting the front since it is not symmetrical over the whole range. When using planars then you can't just go super wide baffle without any tradeoffs at all, I've gotten the most smooth results with moderate wool baffles of around 2x the width of the driver. New planar drivers at Parts Express has a fairly wide baffle and a bit more impact even with a wool baffle. Since I'm building a line of them with a CBT I expect the line to smooth things out somewhat so I'll probably go a wide baffle anyway. Plus it lets me cross lower =)
Addition #2: In the picture I have 3 sheets of 10mm wool carpet. In my later measurements I have found that a single sheet of 10mm wool carpet yields pretty much identical measurements.
Graphs taken from my earlier experiment thread Dipole wool carpet baffle experiment
The dip in the 700 - 1000 hz region is because of the driver, I suspect the culprit is the extremely large magnet which blocks the rear quite a bit.
Old 16th March 2021, 01:44 PM   #147
Ultima GTR is offline Ultima GTR  United States
And crazy overall sensitivity. Active DSP systems could really sing with this driver I think. I'm toying with the idea of 6-8 per side in a line array.
Just curious if you've had a chance to build and test this system? Pictures?
Paul
Old 16th March 2021, 10:23 PM   #148
studiotech is offline studiotech  United States
studiotech's Avatar
Paul
Not likely anytime soon, sorry to say.
Greg
Old 16th March 2021, 11:09 PM   #149
I'm sorry to hear that Greg. Sounds like a complicated reason for not moving forward with the project...
I'm about to place an order for 16 GRS PT5010-8 10" Planar Mid/Tweeters 8 Ohm and 32 GRS PT2522-4 3-1/2" Planar Tweeters 4 Ohm to create a 6½' tall Line Source. I'm considering making a structure like the IRS V with wings to help with the low end response. It'll be all active with a BSS BLU800 handling the crossover duties.
Thoughts/suggestions of things to think about and consider???
Paul
Old 31st May 2021, 10:13 PM   #150
Remlab is offline Remlab  United States
Just bought the slims. I'll be trying them with an active 8th order at 600hz(Maybe a little lower) in a sealed cabinet and DSP'd to flat through 20khz. That should take care of a lot of the 2nd and 3rd HD that's showing up in the plots. There's a few other things I'd like to try also. Should be interesting.
They'll be competing with what I have on top at the moment..
It's not what you don't know that causes trouble. It's what you do know that just ain't so..Mark Twain
New planar drivers at Parts ExpressHide this!Advertise here!
Thread Tools
60 pcs Parts Express 269-570 NSB drivers circa 2005 woofertester Swap Meet 4 13th June 2020 07:54 PM
CSS drivers now offered at Parts Express DiscoJones CSS 2 7th August 2018 10:53 PM
Parts Express drivers to build a L100 clone Sprags Multi-Way 5 9th March 2015 07:46 AM
New Tangband Sub Drivers at Parts Express form109 Subwoofers 1 6th February 2012 05:18 PM
New Audiopulse / TC Sounds subwoofer drivers at Parts Express. BHTX Subwoofers 3 29th March 2008 10:07 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
