Planars & Exotics ESL's, planars, and alternative technologies
OB line array to match Apogee mid/treble ribbon
Old 8th July 2020, 07:20 AM   #1
deepmatt is offline deepmatt
Default OB line array to match Apogee mid/treble ribbon
I have a pair of Apogee Centaur Minors and whilst I like the mid and treble ribbon the bass from the 6.5" isn't the best.
As a project I was thinking of building open baffle line source of woofers to go with the Apogee Ribbons.
Just wanting advice, resource etc. to help me select appropriate woofers, baffle dimensions, crossovers etc. to get the best integration between woofer array and ribbons.
Cheers
Matt
Old 8th July 2020, 09:47 AM   #2
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
Been done by PJBlakey. I wanted to do the same to mine but came to the conclusion my room isn't big enough. I've attached a pic of his build and if I get time will search out the thread.
Old 8th July 2020, 01:44 PM   #3
Itsmee is offline Itsmee  England
Itsmee's Avatar
A few years ago, I bought some Hawthorn Audio Augie 15" as a backup/replacement for my Apogee Stage bass panels should they die, thankfully the Hawthorns are still gathering dust.
Although not a line array, its an interesting alternative; the article has lots of useful information
http://www.firstwatt.com/pdf/art_slob.pdf
I think most people chose the Eminence Alpha-15A
Picture of a single driver SLOB
The Pass Pub: The High-End Off Topic Thread
I'm still debating OB or SLOB Hawthorns with some B&G ribbons
Old 8th July 2020, 11:50 PM   #4
Oooooh I like the look of PJBlakey's one. I wonder if they sounded good. Thanks for the info guys, I'll check it out.
Cheers
Matt
Old 17th July 2020, 03:24 AM   #5
Few is offline Few  United States
Iíve been very happy with the line array portion of this project. A smaller version might work well for you. For open baffle bass you need volume displacement capacity, and probably equalization.
Few
Old 17th July 2020, 02:54 PM   #6
billshurv's Avatar
Matt: I would PM PJBlakey. He was posting here a couple of days ago so should pick up and respond. he was very happy with it at the time at least until the wood split.
Old 17th July 2020, 11:14 PM   #7
Sorry, I just realized my post wasnít completely clear (although Iím not sure itís important). I meant Iíve been happy with the vertical array of six 8Ē woofers, none of which are really designed for open baffle use. With enough drivers, they can handle the equalization necessary to flatten the bass response without running out of linear displacement. Iíve been happy with the planar magnetic line array as well, but thatís not particularly relevant to this thread.
Few
Old 4th August 2020, 11:42 AM   #8
Few - I'm not sure what project your are referring to - is there a thread related to your project?
Matt
Old 5th October 2020, 11:06 PM   #9
Sorry for the delayed response. I just came across your post.
Yes the thread was linked to the "this" in my first post. Here it is again, this time hopefully easier to see (sorry to hide it last time):
DIY planar magnetic + open baffle woofer array
Few
  Reply to this post
OB line array to match Apogee mid/treble ribbonHide this!Advertise here!
Budget mid-woofers to go with a line-array ribbon DeonC Planars & Exotics 15 20th May 2016 07:05 PM
Aluminum for Apogee Ribbon Atom666 Planars & Exotics 2 27th August 2014 07:36 PM
Apogee Diva Cone woofer line array & x over help Africa PA Systems 0 19th July 2012 06:05 AM
Apogee Ribbon Repairable? Help! Bernie7 Planars & Exotics 5 30th July 2011 02:42 AM
Any SoCaller willing to audition NF line array and/or DIY ribbon set-up? Dumbass Multi-Way 0 11th December 2005 08:17 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
