Planars & Exotics ESL's, planars, and alternative technologies
mg12 crossover
mg12 crossover
Old 29th June 2020, 09:58 PM   #1
adie moore is offline adie moore  United Kingdom
Default mg12 crossover
hi, unfortunately my room dictates both speaker and listening positions. I am getting a ~10bd spike at frequencies 120hz down to 60hz. would a notch filter (image attached) work to attenuate this?
I think it would bu I'm looking at about 100 in part to find out, which isn't a problem if it works.
cheers adie
Old 29th June 2020, 10:51 PM   #2
mattstat is offline mattstat  United States
No, that one is to equalize impedance, not frequency response.
If you want to go this route, you are looking for a parallel notch filter (also called a parallel trap circuit). I think it will probably be fussy to get right and not as precise as you want though.
Most people are using DSP for these kinds of issues now. DSP gives you far greater flexibility, which you are likely to need for this kind of application. The miniDSP units are pretty popular, and if nothing else it's a relatively inexpensive place to start to see if you like the result.
Old 29th June 2020, 10:54 PM   #3
ah, nice one. off to google miniDSP.
cheers adie
Old 29th June 2020, 11:00 PM   #4
something like this; Buying a miniDSP 2x4 Boxed DSP module? - SoundImports
not sure I want to add a load of electronics in to the signal path but it does get a lot of good reviews.
Old 29th June 2020, 11:31 PM   #5
Yes, that is their base model and should do nicely to give you a feel for the method with a 2-channel setup. It has plenty of capability for the EQing end.
If you decide you need performance, there is a newer HD version, but it's more expensive.
I understand your reluctance to put extra stuff in the signal path, but most people who go this route wind up happy with the results.
Tuning a speaker's in-room response to your liking isn't always straightforward, so the extra flexibility of DSP is nice to have.
Old 30th June 2020, 03:51 PM   #6
Typo in my last post. It should have read: "If you decide you need more performance".
The HD version runs at a higher sample rate, has digital inputs, higher output voltage, etc.
Old 30th June 2020, 06:03 PM   #7
well for 100 I guess it's worth a go. but I am going to be listening very critically to see if it reduces sound stage and imaging, as I cant help but think it will, and i have just enjoy a quantum leap in the aforementioned with the purchase of a rogue st100. thanks for the pointers mate.
Old 30th June 2020, 09:07 PM   #8
so the more I think about this the more I'm talking myself out if it. if a dsp goes between my dac and preamp then it's going to be taking an analog signal converting it into digital, doing the processing, and then converting it back to analog. that cant be good for the sound. humm.
Old 1st July 2020, 12:03 AM   #9
There's no doubt it complicates the signal path, and it's doing what you described in the digital/analog domains. There are other solutions to the hardware end that cost more and do more (DDRC-22D, OpenDRC-DI, etc. which operate on the digital side). But I was trying to suggest something cheap that could give you a feel for what the equalization can do.
Some form of DSP is likely to simplify the quest to tame your bass, even if it's only an interim experiment.
Assume for a moment that it messes up your imaging or other things, but lets you try 20 different equalization settings to get the bass just the way you want it. That correction curve can then be used to try to produce the passive response shaping circuit you were originally asking about. It'll go a lot more smoothly if you know exactly what you want.
The circuit will likely require modeling as well. It's not something where a cookbook answer is likely to provide an accurate solution in one go. If you don't have a lot of crossover parts lying about and you're dealing with big inductors, tweaking things can get expensive.
Or you may decide that the "10 dB spike" isn't that offensive after all. You didn't give many details about your response anomaly, so I'm not sure if you are describing something that's in your face or if you are just trying to improve a plot. 10 dB variations in in-room response in the bass range are common depending on how it's measured. In some rooms, smooth response is only possible with a lot of care in setup, large damping solutions, etc. (or DSP room correction). Even the reviewers in the Stereophile magazine have some pretty rough in-room plots at times, but they typically say they sound a lot better than they measure.
Anyway, all of this is just one person's opinion, and maybe you'll get luckier than I do when it comes to response tweaks. For my projects, I appreciate having multiple amps, active crossovers, etc. in the early phases of design because it speeds things up tremendously and lets you know when things that seemed like good ideas in theory aren't going to pan out.
Old 1st July 2020, 06:57 AM   #10
thanks for taking the time mate, hope my previous posts didn't come across as ungrateful. like you say, its just a tool that can only help in the long run. if I like what it does for the bass then I can use that knowledge.
its certainly not spoiling my listening and is only noticable on ~30% of songs anyway. I know I was kidding myself thinking I might get a quick fix.
thanks again dude, adie
mg12 crossoverHide this!Advertise here!
Pulseaudio Crossover Rack - multi-way crossover design & implementation with linux Tfive PC Based 769 Today 09:14 PM
Do i need analog active Crossover or Digital Crossover for DIY home theatre speakers? dipankar862 Multi-Way 43 16th March 2017 05:55 AM
Update Maggie MG12 with sub and new X-over marnixmorsink Subwoofers 0 10th May 2014 05:52 PM
Can you use a digital active crossover to design a passive analog crossover ? RickDangerous Digital Line Level 27 1st April 2013 05:59 AM
FS: Magnepan MG12 outboard crossovers (upgraded) jhoak Swap Meet 0 13th July 2012 04:34 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
