Planars & Exotics ESL's, planars, and alternative technologies
esl impedance measurement
Old 30th June 2020, 04:27 AM   #11
bolserst is offline bolserst  United States
bolserst's Avatar
I personally have not used lineout on the UCA202, but in general lineouts are not happy driving low impedance loads. I would not recommend a sense resistor lower than 100ohm. You may find measurements are cleaner if you use something higher like 470ohm.
Old 3rd July 2020, 02:36 AM   #12
geraldfryjr is offline geraldfryjr  United States
Hi There, Been a while since I have posted any thing.
I have much experience in the past with this sort of thing.
Even though it is quite easy to do such measurements with sound cards, in order to get the most accurate results of your time doing so you really should use some buffers between your sound card and the device you are measuring, ie ESL's, Step up transformer's and Caps and such.
For a few reasons,
#1 First and foremost they isolate the sound cards impedances from the device that you are trying to measure.
This including any cable impedances connect to the soundcard and are isolated from the measurement of the device across the reference resistor.
Even the slightest loading can cause a pretty large error as I have found out first hand.
Sorry, but I don't have my graphs handy anymore as they were all produced and posted to the ESL DIY website that is now defunct and now all gone.
Some of those graphs can be found here but my whole tutorial on the subject has disappeared unfortunately as it was a lot of work and great info for all.
#2 They help to provide some protection to the I/O of your sound card.
With my techniques I was able to measure my Step up transformer directly from its output of 4-5KV peak straight in to a brand new (At the time) Asrock 990FX Extreme 4 motherboard and later I started using my GINA24 sound card with no damage to either system (still using them to this day).
In fact with this method I did post some measurements of the testing of the Antek 1206 transformers that everyone started using at the time as it failed and shorted out.
I was lucky enough to repair the transformer and continue testing and those can be found somewhere in these threads.
#3 The sense resistor should be rather low if you plan on taking the measurement with the step up transformer.
The reason being is that any added resistance in the primary circuit effect's the overall impedance curve and Frequency response of the panel output.
Even as much as 1 or 2 ohms can drastically change FR most notably at the Transformer resonance peak on the high end due to the transformer's leakage inductance and transformer's parasitic and panel capacitance added together.
This is a known fact I am sure that you are aware of.
Therefore using a .1 ohm resistance and a buffer opamp with a gain of 10 will give you 1 volt reading across the .1 ohm resistor for 1 amp of current while providing a minimum amount of loading of the primary winding under test.
If you are just testing the panel then yes you could use a higher value.
But you still need to drive the panel with a low impedance buffer even if it is only at a 1 or 2 volt level.
Now as far as that actual resistance, Well I have had issues with measurements not being exactly the same while using different values for the reference resistor with the exact same device being tested.
Why? .... I have not had the time to investigate why this is.
Even though the measurements were pretty much in the ball park to one another, overall, it was the peak of the impedance curve that would change with the value of the reference resistor all else staying the same per test.
Probably not a big deal but I was aiming to get the most accurate results that I could.
See this thread on this issue,
New speaker impedance tool, SimpeS
REW and SimpleS had just employed impedance measurements at the time I was doing this and I have not revisited them since then (or anything for that matter I've just been to busy lately).
I was using Visual Analyser for all of my testing for the most part at the time, it is a great tool if your machine has the power to handle it.
A thread on this very subject is found here,
How to measure capacitor impedance graph
In post #4 are links to the interface and VA that I used,.
Most any decent opamp will work just fine, I just happened to have some excellent ones from LT that I use.
I see VA has been updated since then and I have not tried out the newest version yet, It has all those needed functions built right into it as well, It is an amazing piece of software !!
As far as driving the test unit a good quality audio amp may be used, but not all are DC stable with such a low DC resistance as a load.
My Crown DC 300A worked okay but it was sketchy getting it to work properly at time due to such a low DC resistance load.
For my testing I had made my own high power non-inductance 1 ohm reference resistor out of out of about 30 feet of West Penn balanced cable all folded up.
Since it was made of copper it did change slightly as it heated up but not to bad.
It was during the winter time when I was doing this so I just dropped the dummy load out the window to keep it cool and that kept from burning up, it worked great and got the job done !
As for my buffer I used the Crown to drive my transformer tests when it was meant to be at a high power.
For all other tests for just measuring stuff I came up with nice little DC stable amp using an LT1210.
This allowed me to have something that could handle a very low impedance while only driving with a 1-4 volt peak signal as that is all that is needed.
That circuit is found here,
I never did build a proper PCB for it yet but I was amazed that the thing worked as well as it did on just an old cruddy protoboard, Thanks to the DC servo loop employed in it.
Here is Version 1 of my test jig,
Step-up transformer design
Attached is a detailed sheet of my test jig.
Cheers !!
Keep on DIYin' !!
jer
P.S. to save time here is the link to the impedance jig I use.
http://wb6dhw.com/RLC_Meter.html
Old 3rd July 2020, 06:47 AM   #13
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Gerald, thanks for the overview. I am lucky to have access to a Bode 100 so the measurements are a no-brainer, and I used a small audio amplifier to drive the xover filter.
But I did find out (thanks to member vacuphile) that it was probably wrong to leave off the woofer load when measuring the xover impedance. There is some series resonant circuitry in it which leads to a very low measured minimum impedance of less than 2 ohms.
Paul pointed out that the parallel impedance of the woofer would damp that resonance and probably would lead to a higher minimum impedance. Counter-intuitive, but makes sense.
So I'll re-do my measurement with a nominal 8 or 6 ohms parallel load included.
Jan
Old 3rd July 2020, 07:34 AM   #14
It kinda sounds like a series orientated crossover, I had started on such a design a while back for my desktop ESL using the primary inductance of the transformer as a filter for the woofer.
It was a really cool design and was looking pretty good in the sim's but it required a lot of big caps and no way was I going to use electrolytics in it.
I really wasn't to happy at what it was doing to phase response of the signal either, it looked pretty sloppy, actually the phase was changing all over the place across the whole bandwidth, so I dropped the idea and started working on some direct drive circuits instead that would probably cost less for the whole amp compared to what the caps cost.
jer
Old 3rd July 2020, 02:16 PM   #15
jan.didden's Avatar
As much as I hate to admit, Paul was right: with the woofer connected, through it's own xover, the imput impedance of the combination now stays above 5R. Without the woofer it dipped below 2R.
See attached graphs, blue without woofer (I used an 8R resistor as 'woofer' for the measurements).
Jan
Old 3rd July 2020, 03:44 PM   #16
bentoronto is offline bentoronto  Canada
You really should stick in a resistor of 5 Ohms and see how that plots.
Fry's top left diagram and my posts 2 and 6 are simple and direct. Any sound card or the little DAC is (or should be) designed to drive headphones. So, as long as the load is over 40 Ohms, their output will be fine for your tests... esp if you use the benchmark approach of post 2.
With a benchmark, you can see how your measurement system is working. Without it, you are flying on unverified assumptions.
The ML XO is interesting. There is a series resistor for the woofer - maybe to add tubbiness at resonance or trim loudness. As usual, the ESL XO has necessary protective resistors.
B.
HiFi aspirations since 1957. "When the toilet paper of Experience is depleted, the backside of Reason goes unwiped"
Old 3rd July 2020, 05:24 PM   #17
jan.didden's Avatar
As I mentioned, I have access to a Bode 100. My re-measurement proved my friend right, which was the goal of the exercise.
Jan
Old 3rd July 2020, 06:25 PM   #18
jan.didden's Avatar
I think I should have posted in another thread, my bad!
I'll get out of the way.
Jan
Old 7th July 2020, 10:07 PM   #19
Missed it on first reading: how can the impedance be higher with the woofer connected? Isn't the woofer in parallel with the tweeter? Can you educate me, please.
B.
Old 8th July 2020, 05:09 PM   #20
bolserst's Avatar
If you look at the woofer crossover, you can see that if the woofer is removed you are left with a series resonant circuit. At resonance the impedance will dip to the series resistance of the circuit loop which in the attached example is about 1.25 ohm. Adding an 8 ohm load in parallel with the capacitor provides some amount of damping, thus increasing the impedance at the resonance frequency. Of course below resonance the impedance is reduced with the added 8 ohm load, in line with intuition.
This behavior is seen with most 2nd order crossovers(HP or LP) when measuring without a load, unless the series padding resistor used for level matching is of a high enough value to mask the effect.
  Reply to this post
esl impedance measurementHide this!Advertise here!
impedance measurement software celef Software Tools 2 26th January 2019 05:28 PM
Liberty IMP Impedance Measurement Ardee Multi-Way 22 6th June 2009 12:47 AM
Impedance curve measurement bobsinclar Multi-Way 5 16th November 2006 12:17 PM
Impedance measurement Doug Everything Else 2 9th August 2003 04:50 AM
Vifa Impedance Measurement. Dave Multi-Way 27 2nd December 2001 01:55 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
