Planars & Exotics ESL's, planars, and alternative technologies
Where to find light weight neodymium PA driver for flying drone project.
Old 16th April 2020, 06:58 PM   #1
Nick world of synths is offline Nick world of synths  United Kingdom
Default Where to find light weight neodymium PA driver for flying drone project.
I am designing a drone to play sound. I can 3D print the horn. Would like suggestions for some light weight PA horn drivers. Any search I do for horn drivers only shows high frequency tweeter drivers. I need mid range for voice signal.
Would something like this work? It is a neodymium speaker designed for portable devices.AIYIMA 2Pcs Full Range Portable Speaker 2 INCH 4 Ohm 16W Sound Music Neodymium Audio Speaker Driver For Computer Loudspeaker DIY - Aliexpress
Or this? TEAX32C30-4/B | Tectonic Round Audio Exciter, 30W nom, 30W max, 4Ω | RS Components
Old 16th April 2020, 07:01 PM   #2
Pano is offline Pano  United States
Pano's Avatar
First one yes, probably. Second one, no not at all. But a horn to cover vocal frequencies is going to be bigger than you think.
Take the Speaker Voltage Test!
Old 22nd April 2020, 06:37 AM   #3
ErnieM is offline ErnieM  United States
What's the maximum payload your drone can handle? Unless it's a big drone, you're probably better off with a fullrange driver.
Lightest vocal range horn drivers are about 5 lbs. Faital Pro 3FE22 is about as sensitive as your going to find in a small driver. Weighs in at half a pound. Will be considerably louder than your typical bluetooth speaker driver. A true horn is space prohibitive but you can do a shallow waveguide. Will be better than nothing.
Old 22nd April 2020, 11:55 AM   #4
I have not got the drone yet because I don't know how light the speaker can be made.
I will have and experiment with the Faital Pro 3FE22. What is special about a vocal range horn driver compared to a standard full range driver? I took a horn apart, it was like a treble driver, but the diaphragm was more rigid. I don't really understand the effect of things like the diaphragm stiffness and also the reason the throat diameter is narrower than the diaphragm. Should I hack a Faital Pro 3FE22 to be more like a vocal horn driver?
Where to find light weight neodymium PA driver for flying drone project.Hide this!Advertise here!
Neodymium Magnets - Strength/Weight fidelia91 Headphone Systems 1 11th December 2014 03:04 AM
Light weight (sub)woofer driver? eRiCdWoNg Subwoofers 25 1st July 2006 03:06 PM
Light weight speaker system amirmk Multi-Way 5 14th November 2004 04:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
